Stop problem (Solved)
08.05.2020 16:56 # 1
efd63
my friend every pouch hello 1998 model peugeot 106 xs my car & nbsp; have the car stopping immediately when running first & nbsp; after the engine warms up & nbsp; there are 2 fans as you know & nbsp; 2. After the fan has been put into operation, the sold out blade stops at the end, stopping in the same way when I am running again. In the meantime, I also have the same system lpg in the arc, while doing the same problem in the lpg.
08.05.2020 16:56 # 2
efd63
help please?_
08.05.2020 16:56 # 3
Don't hurry, come on, let's get to know you.
Please click on the link in my signature.
08.05.2020 16:56 # 4
estair
the probability is the problem with the idle engine but it would be better if you connect it to the pc. but the priority is to clean your throat butterfly
08.05.2020 16:56 # 5
How did you observe that stopping happened with the 2nd fan being activated?
08.05.2020 16:56 # 6
elsoberano
Same as my problem, I changed the idle adjustment valve last week, when the air conditioner turned on, the fan stopped when it was activated and now it has recovered.
08.05.2020 16:56 # 7
efd63
After the car warms up, the engine gets hot and I get out of the car and look at the fans.
08.05.2020 16:56 # 8
yigiteroglu
A similar problem has been resolved today with the idle engine replacement. My vehicle is like in my signature.
08.05.2020 16:56 # 9
tolgatumer
I have the same problem, my friend. When the vehicle gets hot (even on the road, it almost hits the inside of the cabin like a hawk), the engine stops. There is no problem when it first runs .. & nbsp;
Vehicle 1.6 gasoline 307 .. & nbsp;
If you solved the problem, I would be glad if you share. & nbsp;
08.05.2020 16:56 # 10
efd63
nowadays it stops again when it starts working better but after 2-3 minutes there is no problem & nbsp; :))
08.05.2020 16:56 # 11
mavinet08
I had the same problem, the first starter does not press, sometimes sometimes it touches the gas, it stops, as you stated, the engine warmed up and went to the peugeot special service, they looked, and the injector cleaner added, half the tank filled, I saw the difference the next day and when the tank was finished, I filled the tank with 45 liters and filled the tank with 45 liters and injected from the oil office I put a cleanser and the problem is completely solved now!
08.05.2020 16:56 # 12
EmSul
He started to do it for me too, especially when he was just working or when new fuel changed, that is, when he switched from gas to gas or gas to gas, both of them do not stop idling, he stops and stops, especially when I come to the lights, when I was idle, I was able to hold the idle, the direct cycle falls and stops, I was mad, I just came from the market 3 times stop in the lights ... Does the idler make it through the regulating valve?
08.05.2020 16:56 # 13
erden1978
The green or blue sender may be malfunctioning. One of them was transmitting the engine temperature to the brain. The room adjusted the idling according to the temperature of the engine.
08.05.2020 16:56 # 14
caster21
the same problem exists in me 99 model 206 xr vehicle stops working when the engine is cold when it stops giving gas when it stops wasting it stops when it stops the gas was dismantled in the throat butterfly, it got cooled out of the car
08.05.2020 16:56 # 15
Nasuh35
First of all, my master has been pretty good but I have 98 xs, the same problem happened. How did you find a solution?
