Stop problem (Solved)
08.05.2020 20:28 # 1
SET06
Hello friends, my car is 2002 1.4 petrol 206. When the car is going to stop and then it works immediately. Meanwhile, the yellow engine fault lamp lights up and turns off. It may be the reason.
Edit: Friends hadn't done it for 2 days after cleaning the sockets to the brain with contact spray, but I think the car tricked me and started doing it again. I showed it to the master, said there is no problem in the brain sockets and the fuse panel. We looked at the fuel float under the back seat, and there was a gas leak, the float was pretty old. I replaced it with a new one because it stems from this. I got into the vehicle for 3 days without any problems, but eventually made the same stop failure. When we connect the vehicle to the computer, it does not show any fault record. I am waiting for your comments.
SET06 2017-09-17 13:11:57
08.05.2020 20:28 # 2
kilic46
Is the brother waving and stopping, or is it closing directly? This problem still persists in me. Idle engine, valve adjustment, throat butterfly cleaning, spark plug replacement, injector cleaning etc. A suction manifold connections, an oxygen sensor remained. At the OPET, it feels as if it gives dirty gas. When I last took it, only LPG started to misfire.
08.05.2020 20:28 # 3
SET06
There is no fluctuation in brother or sister. The vehicle does not have gasoline cylinders.
08.05.2020 20:28 # 4
I recommend that you look at the electrical installation as if the gas pump is cutting electricity. either the pump is defective or there is a problem with the installation. electrical chassis of the vehicle may be oxidized. Have the chassis checked. Have your gas pump pressure measured.
08.05.2020 20:28 # 5
SET06
Thank you very much for your comment. I will take the vehicle to a good electrician tomorrow.
08.05.2020 20:28 # 6
eng34
The same problem I had in me was cutting gas, like stop etcek. The map sensor has changed, it has improved. I think you have a check.
08.05.2020 20:28 # 7
cino
100 per 100 oxygen sensors
08.05.2020 20:28 # 8
SET06
The topic is up-to-date friends.
08.05.2020 20:28 # 9
kilic46
As Soner said, I have to look at the electrical installation. My vehicle and LPG had started to misfire. When the LPG master moved the cables on the coil, he said that the engine was sailing. But the most important thing is to find an electrician. There is a familiar electrician, but the room does not want to touch a lot.
08.05.2020 20:28 # 10
alp-han
Similar problem happened in my vehicle, I think have the oxygen sensor checked. Oxygen sensor if there is a state of gas, cutting, shaking and stopping when the vehicle is going
08.05.2020 20:28 # 11
SET06
Guys, we tried to replace the crank sensor and it didn't improve. We checked the spark plugs, they have no problem. Ignition coil failure to the computer has dropped. We changed it on the coil and the problem still persists. When you make this mistake, the smell of gasoline comes in. We just replaced the gas pump.
08.05.2020 20:28 # 12
SET06
Friends, the problem was in the brain, we had the brain repaired.
08.05.2020 20:28 # 13
Kocak
get well my brother god don't crash it
08.05.2020 20:28 # 14
SET06
Thanks bro
08.05.2020 20:28 # 15
I am glad your problem has been solved for the past. What kind of problem did the brain have, did oxidation water penetration happen?
08.05.2020 20:28 # 16
SET06
The water from the sockets has walked inside and it is obvious that the electronic card has been out of balance.
07.04.2021 11:28 # 17
leamino
2 years I have similar problem there is and it could not be solved. Today a master said, I wonder if there was a force on the doors? the car thinks itself stolen and locks itself.
I remembered a moment, there is a problem at the back door and it cannot be opened from the inside. said yes, cut it off! I will go and repair it tomorrow and see if this problem will be solved!
I wanted to write here, maybe one day it will be in someone else's job.
I changed something because it might be because of it seems like a simple DOOR problem. .
