Stop problem at Pego 206 LPG
08.05.2020 21:26 # 1
Yasam79
LPG, which is a great vehicle in gas, also causes trouble. Today it stopped 4-5 times in particular, especially in red light, there is a problem in 1st gear. When I accelerate normally there is no problem. What do you think could be the problem?
08.05.2020 21:26 # 2
ismailkaya
Can you write the engine version of your vehicle
The engine version with 1.4 16v 90 hp?
08.05.2020 21:26 # 3
Yasam79
Just like you said
08.05.2020 21:26 # 4
Yasam79
Distress throttle is out, guys. I have it cleaned, for now there is no problem.
08.05.2020 21:26 # 5
ismailkaya
If there is no fluctuation in the idle, start your vehicle at idle, the engine will start operating at idle after the engine temperature reaches 50, the hood will open at the last stage of the heater and the vehicle will continue to run at the top of the catalyst, and the vehicle will immediately switch to the gas after it will run on the gas, then the lamps will be turned on, then the lamps will be turned on, and the lamps will be turned on Stop your vehicle, install the sensor plugs then try to see if it will stop, if there is a fluctuation in your idle, your vehicle will stop again and let your information come easy
08.05.2020 21:26 # 6
Yasam79
Thank you so much
08.05.2020 21:26 # 7
ismailkaya
the throttle must be cleaned, but your vehicle will stop again
08.05.2020 21:26 # 8
Yasam79
Beyinci also looked at the error codes and the throttle error came out. Then he deleted it all. Let's see what happens now. I'll do what you say. Let's see what will happen.
08.05.2020 21:26 # 9
ismailkaya
if it keeps stopping apply what i say
08.05.2020 21:26 # 10
Yasam79
[QUOTE = ismailkaya] If it continues to stop apply what I say [/ QUOTE]
I will do what you say but there is a lot of fluctuation unfortunately
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
