Stop problem |
| 10.08.2020 10:29 | # 1 |
| 10.08.2020 14:05 | # 2 |
sonerkyl |
There may be several reasons for this. Idle sensor, I say clean it and I say the throttle. Also, the lpg regulator diaphragm may be torn from it.
| 10.08.2020 14:35 | # 3 |
I removed the idle sensor and the throttle and cleaned them with a lining spray, sir. I installed it after wiping and drying it thoroughly, but there is nothing changing unfortunately.Is it enough if I do the lpg regulator diaphragm control from the entrance to the intake manifold? It seems that adaptation should be done when the throttle-idle engine is cleaned or changed. After waiting, we put it back. Then, turn off the ignition, turn the ignition on and off 9 times without starting the vehicle and start it on the 10th, and the adaptation is complete. Is such an information true, my teacher? At least I will make such an adaptation when I buy a new idle motor and plug it in. [QUOTE = sonerkyl] may have several reasons for this. Idle sensor, I say clean it and I say the throttle. Also, the lpg regulator diaphragm may be torn from it. [/ QUOTE] arifbsrn2020-08-10 14:36:03
| 10.08.2020 16:03 | # 4 |
If there is a lower oxygen sensor in the catalyst, that sensor may be defective, pull the plug from the socket and use it with the plug, let's see if it will stop.
| 10.08.2020 16:23 | # 5 |
As far as I know, İsmail Master, there is one oxygen sensor, but I could not see the oxygen sensor after the catalyst at the partsouq site right after the exhaust manifold (number 1 in the picture). If there is, where exactly can it be? (Also, there is no engine fault light on the indicators, etc.) [QUOTE = ismailkaya] If there is a lower oxygen sensor in the catalyst, then the sensor may be defective. 10 16:25:36
| 13.08.2020 11:18 | # 6 |
Hello guys. I did not do anything to the car, but I said I should press a contact last night. I looked and worked perfectly. I did not understand where it stopped, the fault was resolved. I toured a little. I stopped and restarted again and again, there was no problem. I guess there is a lack of contact in one of the parts. What is your opinion?
| 17.08.2020 11:32 | # 7 |
There is 1 lambda sensor in your vehicle. In the following years, with the advancement of technology, the lambda sensors became 2. I can say the following about your problem. There may be a problem with potentiometer, idler motor, air flow sensor, coil or injector plug or cables. Sometimes the plugs may lose their conductivity or there may be problems such as breakage and deformation in the cables. It is useful to have them checked Berkay Erdinç :11th
