Stop problem
08.05.2020 21:22 # 1
gnlcln3542
Hello everyone, I went to the industry for oil care about 2 weeks ago. After that, my car, which runs like clockwork, was very strange after maintenance. Let me tell you without further ado. I run it 3 times, then it gets better then it stops after 1 2 times while driving. What could be the reason?
08.05.2020 21:22 # 2
If the diesel filter is changed, the problem is caused by a 100% diesel filter.
08.05.2020 21:22 # 3
gnlcln3542
If the [QUOTE = sonerkyl] diesel filter has changed, the problem is due to the 100% diesel filter. [/ QUOTE]
Yes, the diesel filter has changed, I have read in a few forums, it says that it can also be caused by idling sensor
08.05.2020 21:22 # 4
I do not think that after a maintenance like you, a friend did not work in the vehicle, it changed when he changed the diesel filter. Idle sensor often stops causing fluctuation. for example if you said the crank speed sensor
08.05.2020 21:22 # 5
gnlcln3542
[QUOTE = sonerkyl] I don't think the same as you care then a friend did not work in the vehicle, it changed when the diesel filter changed. Idle sensor often stops causing fluctuation. you could have said the crank speed sensor for example [/ QUOTE]
I understand, if I buy the filter, can I change it myself
08.05.2020 21:22 # 6
If you know how to get the air, you can change it, Hodja. YouTube videos are available. But make sure that the filter is absolutely original, get 20-30 TL more from the authorized service or the part you trust. Also check the filler filter box before leak etc. Maybe there is air in there.
08.05.2020 21:22 # 7
gnlcln3542
I just came from the industry, the boiler where the diesel filter is installed is making the air, the problem was caused by this, my problem was solved by applying a different system thank you for your interest
