Stop Problem
08.05.2020 19:34 # 1
muallimsamil
Friends good evening ... 2005 I have 206 sw. Often there is a problem of stopping immediately in the morning (routine not always) after working on the first starter. Or it stops when it switches to gas. Works on the 3rd 4th starter. I have to give gas sometimes after the start. Does anyone have this kind of problem. Having a solution proposal? Thanks.
08.05.2020 19:34 # 2
muallimsamil
I have been using gasoline for a week on a recommendation. The problem has been largely passed. Your information.
08.05.2020 19:34 # 3
These problems usually occur as a result of malfunction of the parts and sensors in the lpg system. yes, when you use gasoline for a while, as you said, the problem starts to disappear. my advice is to have gas breakers lpg map and temperature sensor and regulator control in the vehicle. Have the throttle cleaned as well. Let's make the lpg setting in motion with the vehicle, the most healthy lpg setting is done only in this way. The lpg setting generally performs the standard calibration from the pc.
