Stop Painting
08.05.2020 14:53 # 1
tigerland
Hello friends,
I wanted to make the taillights, which had cracked and faded, become zero and I achieved the desired result with a few materials and wanted to share with you.
1 Piece Transparent Red Stop Spray
1 Piece of Japanese adhesive
1 Piece 1000 M. Sandpaper
tigerland 2010-09-05 02:53:48
08.05.2020 14:53 # 2
Aytac
good health to your hands ...)))
08.05.2020 14:53 # 3
tigerland
[QUOTE = Aytaç] good health to your hands ...))) [/ QUOTE]
thank you :) I can't break it because I love it from the factory .. I painted the fog lamp from the extra .. it was nice I add the new ones :)
08.05.2020 14:53 # 4
MaximuS
my friend is really good health, super ...
Although I looked very carefully, I could not choose the cracks! enjoy it...
08.05.2020 14:53 # 5
tigerland
[QUOTE = maximus]
closely, it is evident in the reflection of the light and it will be so :) I prevented the water from entering the steam and gained a bright red appearance .. thank you
08.05.2020 14:53 # 6
tigerland
Meanwhile, the last painting is the crack on the top, the unpainted version on the bottom ..
08.05.2020 14:53 # 7
alpbeyazi
good health to your hand ... use it with yours.
I heard by explanation .... to inform the friends who will do ..
remove the stops ..
water sand (I do not know the number - the finest sanding), walk 1-2 stops without pressing on the stops
while painting, spray the paint without approaching your stops more than 25cm and aim at a single point. Other types of paint will flow.
without forgetting. Wrap the back part (black part) of the stops with paper tape and newspaper so that they are not red.
Embarrassed
the alpbeyaz 2010-09-05 11:03:29
08.05.2020 14:53 # 8
TURAN61
It seemed a little darker to me. Is it lost or when I see the reversing gear or the signals work?
08.05.2020 14:53 # 9
tigerland
[QUOTE = TURAN61] seemed a little dark to me. Is it lost or seen easily when the gear shifts back or the signals work? [/ QUOTE]
I tested it at night, the colors are normal, there are white and orange signal glasses in the red glass of the stops. I put it in 4 layers.
08.05.2020 14:53 # 10
TURAN61
You dried it every time and put it in 4 layers. No problem if it seems. I will do 307 me Sırıtma
08.05.2020 14:53 # 11
tigerland
Yes, I did not dry with the hair dryer at every stage, don't do it in the wind, but :) I did the 1st stop in the wind, it became mat, then I did it inside.
08.05.2020 14:53 # 12
tigerland
08.05.2020 14:53 # 13
BuRCaK
Where is the red stop spray located?
08.05.2020 14:53 # 14
alpbeyazi
bare you bare you don't ask Confused We go from the gardener, we buy together ... Did you say top paint everywhere? I saw red black green yellow or even orange Disapprove
08.05.2020 14:53 # 15
hasimayaz
If you paint in red, the signal will not be yellow, you will not be able to pass the inspection .. there are transparent spray varnishes, try it. hasimayaz 2010-09-05 21:03:44
08.05.2020 14:53 # 16
deniz_206
[QUOTE = hasimayaz] If you paint red, the signal will not be yellow, you cannot pass the inspection .. there are transparent spray varnishes, try it. [/ QUOTE]
just as seriously flawed
08.05.2020 14:53 # 17
tigerland
[QUOTE = alpwhite] bare you don't ask Confused We go from the gardener, we buy together ... Did you say top paint everywhere? I saw red black green yellow or even orange Disapprove [/ QUOTE]
hepsiburada.com MOCATA I would recommend Made in Italy 22 TL
08.05.2020 14:53 # 18
tigerland
the glass inside the manager is also available in separate colors.
08.05.2020 14:53 # 19
TURAN61
Do you have a picture taken at night and a reverse gear? I think yellow and white light up again
08.05.2020 14:53 # 20
BuRCaK
I don't know, manager, I've never painted Sırıtma
I went directly from the original to LED
Page : / 2
