Stop malfunction
08.05.2020 19:39 # 1
Omer_mydnc
When my friends press the brake when my car is on the right rear parking bulb, the parking bulb ends and could it be because of the oxide that has already taken water?
08.05.2020 19:39 # 2
Omer_mydnc
Hello friends, did you have any ideas or ideas?
08.05.2020 19:39 # 3
talip206
Did you disassemble the bulb? The stop and parking bulb are the same, only two steps. That is, when the park is on, the light comes on, it presses the brake more strongly. If you have plugged the wool of the bulb incorrectly, the opposite will happen, as you mentioned. If it is wrong by checking it while installing it, turn the bulb and plug it back in and try again.
08.05.2020 19:39 # 4
Omer_mydnc
Hello, I changed 2 ampoules 1 week ago, I would like to draw my attention again.
08.05.2020 19:39 # 5
samet206
This kind of problems can happen due to oxidation, it happened to me once before.
