STOP LIGHT
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:44 # 1
teoman_40
& Nbsp; & nbsp; & nbsp; My friends car (2004 307 XR 1.4 HDı) has a fine crack in the left rear stop.
08.05.2020 16:44 # 2
Kemanyak
Fill the crack with japanese or silicone, then remove and dry the stops.
08.05.2020 16:44 # 3
ibrahim YILDIZAK
[QUOTE = teoman_40] & nbsp; & nbsp; & nbsp; My friends car (2004 307 XR 1.4 HDı) has a fine crack in the left rear stop. [/ QUOTE]
Don't try to dry it by keeping the air in. I made this mistake. Even if there is a small piece of stone, it cracks the stop glass. I fell into this mistake in my fog, my left fog glass was broken.
08.05.2020 16:44 # 4
teoman_40
Can I disassemble and clean? Do you have illustrated explanation, how do you disassemble it?
08.05.2020 16:44 # 5
elsoberano
[QUOTE = teoman_40] Can I disassemble and clean it? Do you have illustrated explanation, how do you disassemble and do it? [/ QUOTE]
If there is a narration about painting, etc., I would be very glad that I have the same problem.
08.05.2020 16:44 # 6
ibrahim YILDIZAK
I know it is very difficult to remove the headlight, but I can not say anything for the stop, but as far as I know there is a material that loosens the silicone.
08.05.2020 16:44 # 7
teoman_40
It is very easy to disassemble the friends. Firstly, we remove the carpet in the trunk (it is enough to remove the broken lamp on that side), then we have 2 screws holding the stop, okay. To reach part & nbsp; I need to separate from the adhesive places, I don't dare to break it. It must have been caused by the squeezed cooler spray, there was vascular cracks in the stop (we left it to the sun to warm it up, then it was cold when it ate).
08.05.2020 16:44 # 8
teoman_40
http://img843.imageshack.us/img843/3817/img1785ty.jpg
08.05.2020 16:44 # 9
goktug
I ripped off a month ago, guys. It is very simple as described above. There are two screws holding the stopper. one is outside and the other is underneath the upholstery, nothing is left behind ...
08.05.2020 16:44 # 10
goktug
Also, as your friend says, you cannot reach the part that gets water. you have to break some places to open it, which is not preferable. Don't mess with the glue. They make it like original for 5 TL in industry. But in the future it falls weak and the headlight breaks in a small blow. I had it built 2 years ago. It was fine, but I put on a new one that the kids touched and broken the ball ...
