Stop lamp and abs light.
08.05.2020 14:54 # 1
307P
Hello friends, I have 307 vehicles, I would like to consult you .. this is 5-6 days, there is an abnormality in my car, when I turn the ignition after abs vs lights turn off, the STOP lamp is flashing 2-3 times with the ABS light after the car starts (ABS light is continuous, the stop lamp is flashing intermittently as long as the abs is on]? I took the car to the special service, wait for 3-4 more days, maybe the abs is resetting itself, if it is not said, it comes when the light comes on, it happens when the engine is cold. I would be glad if you were friends ..?
08.05.2020 14:54 # 2
dbmaster
In the first place, check the current of the battery, if there is any play, the errors of the vehicle will be completely corrected by guessing ...
08.05.2020 14:54 # 3
Ozgur
Your battery is weak. Replace your battery. The same happened with me.
08.05.2020 14:54 # 4
voodoo
if your hydraulic oil level is dust ... you can check it ii
08.05.2020 14:54 # 5
307P
Friends, what could be the connection between the abs and the battery? Where can I get it checked?
08.05.2020 14:54 # 6
voodoo
[QUOTE = 307P] Guys, what connection could the battery have with the abs light? Where can I get it checked? .. [/ QUOTE]
It is a system related to the abs brake system ...... anti blocked brake system ..... it is related to the braking system that has failed.
08.05.2020 14:54 # 7
307P
[QUOTE = voodoo] [QUOTE = 307P] Friends, what could the connection of the battery with the abs light? Where can I have it checked? .. [/ QUOTE]
It is a system related to the abs brake system ...... anti blocked brake system ..... it is related to the braking system that has failed. [/ QUOTE]
I mean, I am surprised that I will do it, if it does not pass, I will leave it to the service 2-3 days later, but I hope it will not leave until the day, it is out in terms of the new 110,000. Wall
08.05.2020 14:54 # 8
Ozgur
When you find out that you have a connection with the battery when you have a problem in the service, it would be nice if you write it here.
08.05.2020 14:54 # 9
307P
Okay guys, thanks for the help. I hope it won't cost you a lot.
08.05.2020 14:54 # 10
307P
Friends, I took it to the service today and looked at the battery, but since the battery was not a problem, I did not leave it today, I will leave it to the service tomorrow.
08.05.2020 14:54 # 11
voodoo
[QUOTE = 307P] Guys, I took it to the service today and checked the battery, but since the battery was not a problem, I did not leave it today, I will leave it to the service tomorrow.
write to friends who know a lot, that answer is special ...
08.05.2020 14:54 # 12
voodoo
if it is not because of the low level of hydraulic oil ... abs lamps contamination of abs sensors. between the brake pads and discs, it may burn with mud and excessive dust. they wash it down to a very small figure.
08.05.2020 14:54 # 13
307P
Well, it may not make sense from mud, but now the car is already in the service, what are they going to say? What was the problem?
08.05.2020 14:54 # 14
Ozgur
I was very curious about the problem. My battery was fixed immediately. He said so in the service .. already the battery was 5 years old. Gülme
08.05.2020 14:54 # 15
307P
The car is still in service and there is still no sound.
08.05.2020 14:54 # 16
naksi
The guys started the same problem in my car today, I would appreciate if you have any information about the solution of the problem and if the service was able to find a problem, can I be in the rain in Istanbul these days?
08.05.2020 14:54 # 17
307P
Where can I wash the voodoo gold? There was no malfunction in the car, only the sensors have been cleaned, now I am going to buy the car, but I do not know if the problem has improved? ..
08.05.2020 14:54 # 18
307P
The vehicle was checked in the private service, but no malfunctions were detected etc. Sensors were cleaned only but still that light is interesting. Gülme
08.05.2020 14:54 # 19
sercinho
When you apply the brakes, does the abs go into action?
08.05.2020 14:54 # 20
307P
Valla, as far as I can follow, the abs is no problem, it comes into play, I am confused.
Page : / 3
