Stop in air conditioner
16.08.2020 12:23 # 1
brokenheart
Hello friends, all of you. I just joined you and wanted to share a topic with you. First of all, I have a problem with my 2007 model 1.4 fever pegout vehicle and if you have had problems with this issue before, can you please help. "My vehicle stops when the air conditioner is on the open road". This situation occurs when I press the clutch, brake or my foot is off the gas. It does not stop when it is running idle [when the air conditioner is on]. I showed it to the electrician, the biker, the air conditioner and the auto gasman, they said there was no problem, but I could not find a solution, I would appreciate it if the friends who have knowledge on the subject helped, by the way, I tried the same thing in both gas and gas. Thanks in advance.
17.08.2020 01:58 # 2
ismailkaya
Does your vehicle have an idle fluctuation? If not, unplug the lower and upper oxygen problem in the catalyst and use it like that. Will the problem continue? Let's see if it will stop, stop while your vehicle is working properly at idle, then unplug the sensors.
17.08.2020 12:14 # 3
Do you have LPG in the vehicle?
17.08.2020 13:13 # 4
brokenheart
#ismailkaya Fluctuations in my vehicle are very rare, maybe once a month or so
17.08.2020 13:14 # 5
brokenheart
#sonerkyl Yes, I have LPG in my vehicle, but the same problem happens in gasoline, I had the throttle cleaned and adapted
17.08.2020 14:19 # 6
First of all, there may be gas leakage in the lpg regulator. If you use it in gasoline, the gas in the regulator comes to the manifold and mixes into the combustion chamber. Although this problem usually causes it to run late in the first run, it can also cause a stop event. Also measure the pressure of the petrol pump.
17.08.2020 14:47 # 7
brokenheart
Sonerkyl I went to the autogasci and he said that the gasoline pressure is normal, there is no problem with the gas, my car works normally when it starts up, it works normally at 1000 rpm until it warms up, then it drops to 900 rpm after a short time.Even when I turn on the air conditioner, there is no idle fluctuation just the first time it is turned on. the room is normal. Believe me I showed the places I could show, I couldn't find a result
17.08.2020 22:58 # 8
ismailkaya
The full engine type of your vehicle is flat 1.4, 75 or 90.
18.08.2020 00:11 # 9
brokenheart
ismailkaya 1.4 75 gasoline
18.08.2020 19:31 # 10
talip206
Have the idler motor on the throat throttle checked. I think the two of them should be carefully removed and cleaned with the throat butterfly.
18.08.2020 22:22 # 11
brokenheart
talip206, today I noticed my car has a little rhonati fluctuation, but if we make an evaluation out of 10, there is a fluctuation of 10/2, the room is very, so the idle engine is like solid and I had my throat throttle cleaned. I've done most of the things that can really be done, but nobody can tell me anything clearly. I showed it to the special service masters who were trained in the service, always bikers, gasmen, chemists and electricians, but they all say that it is not a problem, I do not want to go to the service at the last time, but there is a very high price.
19.08.2020 08:05 # 12
I understand, teacher, many things have been done. like this the latest engine ecu going. I have to think that the throttle is out of order.
19.08.2020 15:15 # 13
ismailkaya
When you are available, call me while you are in front of your car and I will show you two places to look or have a look there. 05350674060 İsmail KAYA video call from watsapp
19.08.2020 15:27 # 14
brokenheart
I can call ismailkaya during the day, thank you very much.
