STOP going to LPG
08.05.2020 17:54 # 1
ekinoks44
Good evening everyone .. When I start my car for the first time, it stops when I switch from gasoline to LPG. Should I clean the throat butterfly? I do not know if it is also relevant, sometimes it stops when I stop at the lights or when I take the N to the gearbox in the D position when the car is glowing. I would be glad if you could help.
08.05.2020 17:54 # 2
TuNeR_32
the oxygen sensor seems to be faulty. This may be the reason why it gives off gas to itself.
08.05.2020 17:54 # 3
C!N
As the friend says, the oxygen sensor is probably.
08.05.2020 17:54 # 4
kimyaci58
Increase the transition temperature of your vehicle to LPG a little more. I think it solves the problem. If you are having trouble stopping in gasoline, clean the throat butterfly.
08.05.2020 17:54 # 5
ekinoks44
[QUOTE = onurazgin] maybe protesting the gasoline hike Cool [/ QUOTE]
But as if he doesn't want to switch to lpg Big smile
08.05.2020 17:54 # 6
ekinoks44
I'll take it to the LPG service this weekend. Let's see what happens.
08.05.2020 17:54 # 7
pierson
hello ... my car 2002 autmatic gear lpg li car ... i don't know from lpg but ... sometimes it stops ... especially in the city ... why the car stops ... what should i do?
08.05.2020 17:54 # 8
pierson
Why does an automatic vehicle stop ... will I take it to the industry now ... to the lpg service or a normal master?
08.05.2020 17:54 # 9
Serkan
I had the same problem, the dealers do not understand much from the setting, I talked to the lovato headquarters, they contacted the dealer and made the phone on the settings, there is a setting called return from cutoff, they made the gas correction 30%, the injection trigger number made 25%, 3 thousand km and about He has not stopped for 1 month.
08.05.2020 17:54 # 10
serkans
I had the same problem with me.
