Stop gas pressure
08.05.2020 21:07 # 1
littlenikksay
Hello friends, first of all, the 1.6 1.6 lpg
When the car is running at idle in gasoline, when I press the gas in an instant, it does not eat gas, the speed falls, the engine sounds small, popping sounds and even stops. When I press the gas slowly, there is no such problem.
When I make a dip gas while driving, the vehicle eats delayed gas for 1-2 seconds then jumps off
Today I disassembled and cleaned the throttle still has not recovered
Does anyone have the same problem or can help?
08.05.2020 21:07 # 2
Aykutemre92
You need to look at the Gas Setting There may be a malfunction in the lpg brain or medicine
08.05.2020 21:07 # 3
littlenikksay
[QUOTE = Aykutemre92] You need to look at the Gas Setting There may be a malfunction in the lpg brain or medicine [/ QUOTE]
It does it on gas but not on gas
08.05.2020 21:07 # 4
boruc
Looks like an ignition problem
08.05.2020 21:07 # 5
erdiano
Hodja, I think I am having this problem. When I start my car with 1.4 petrol 307. for the first time, when the car is not switched to LPG, I press the gas, I hear that popping sound in the cold weather and does not eat gas. Sometimes I start the car and it stops after 2-3 seconds. It does not usually happen at the second run. He does this problem from time to time, and occasionally does not.
I recently mentioned this problem when changing the charging dynamo in the auto electrician. Master tied to the computer. The lower oxygen probe is faulty, he said. "It doesn't work with the upper oxygen probe," he said. He showed me the values on the computer, he said that the upper one should follow the values exactly, but as far as we can see on the computer, the lower oxygen probe (also called oxygen sensor) was going to be inconsistent. I haven't changed the piece yet, I don't know if it really stems from it. I think it had a price of 250-300 liras.
08.05.2020 21:07 # 6
littlenikksay
[QUOTE = erdiano] Hodja, I think I am having this problem too. When I start my car with 1.4 petrol 307. for the first time, when the car is not switched to LPG, I press the gas, I hear that popping sound in the cold weather and does not eat gas. Sometimes I start the car and it stops after 2-3 seconds. It does not usually happen at the second run. He does this problem from time to time, and occasionally does not.
I thought of cleaning the upper oxygen sensor, but I couldn't disassemble it.
