stop failure in peugeot partner adventure display
08.05.2020 16:34 # 1
O.Sozbir
slm 2006 model 2000 mtor peugeot partner adventure in the winter care since I put it in the anti-scratch stop light has been burning in the sender and the upper right is running on the right cooker the light is on, so the engine water is called deficient, but the problem is not the same fault, the friends will be helped with the same fault.
br>
koliva 2012-02-02 07:35:52
08.05.2020 16:34 # 2
peugeotefe
There is a black sender on the reservoir reservoir where the engine water is put in. My friend may have plugged it in. The water may be missing.
08.05.2020 16:34 # 3
O.Sozbir
we checked the engine water, the engine water cover is freezing, it was said, we changed the cover, the engine water is above the level that says max, I don't know if I do this problem above the temperature is not over 70 when the fan is on
08.05.2020 16:34 # 4
peugeotefe
Check the socket of the water level sensor. If the socket is in place, the sensor is broken.
08.05.2020 16:34 # 5
O.Sozbir
tomorrow morning my first job will be to check it, thank you for your interest good night
08.05.2020 16:34 # 6
lider_27
I think he would never see if he was from the sender, and shows the temperature at the end of 130, stop flashes, this was just happening to me. goes out, but actually there is no problem with the heat, the customer is working on the solid fan, but it is working all the time, it does not pass anymore.
