Stop (Central Alarm System) warning lamp
08.05.2020 20:53 # 1
Egemen01
Hello,
The stop lamp of my vehicle is on and is overheating. The coolant was missing, I filled it, but the problem persists. I looked after the vehicle started and stopped. A muddy water came out of the coolant tank. What should I do. Can you help with the subject?
08.05.2020 20:53 # 2
talip206
It may have had air. Have air and observe Is there any missing?
08.05.2020 20:53 # 3
Replace the cover of the reserve water tank first. As our friend who wants to observe, says, If there is overheating and oiling in the water like tahini, the cylinder head gasket is gone. It usually stems from driving antifreeze.
08.05.2020 20:53 # 4
boruc
If there is water such as mud, it may be mixing with water. Cry
08.05.2020 20:53 # 5
KILIC
If there is a glassy substance, this is bad. I think you can clean the tank again and follow it.
08.05.2020 20:53 # 6
tigrap
[QUOTE = Egemen01] Hello,
The stop lamp of my vehicle is on and is overheating. The coolant was missing, I filled it, but the problem persists. I looked after the vehicle started and stopped. A muddy water came out of the coolant tank. What should I do. Can you help with the subject? [/ QUOTE]
By the way, is there any LPG in the vehicle?
