stop at first start
08.05.2020 16:14 # 1
hamham
friends always stop at the first start, I run it again, I root the gas, it does not get gas, I get the gas after a few seconds, I progress, this time slows down even though I do not gas it, it accelerates again. gotta thank you in advance
08.05.2020 16:14 # 2
zavur
Gas or LPG?
08.05.2020 16:14 # 3
Ako06
There may be some issue with the cycle reader. greetings.
08.05.2020 16:14 # 4
hamham
The vehicle stops at the first start with LPG and then gives gas.
08.05.2020 16:14 # 5
Look at the throttle ..
08.05.2020 16:14 # 6
hamham
If you are laedri mrb denizlidem, can you recommend me a solid reliable private service rather than denizliid
08.05.2020 16:14 # 7
3. Auto technician in the industry..Peugeot is not a special service, but the problem is not a special problem for peugeot. If you need parts, I recommend you to visit the industries.
08.05.2020 16:14 # 8
hamham
I don't know much, when I have a problem, I am looking for a reliable private service.
08.05.2020 16:14 # 9
zavur
The lpg system may not be compatible with the vehicle, does it do it on gasoline?
Connect your lpg brain to the pc, look at the operating temperature, if it is low, it may stop because it throws as early as 15 degrees. The temperature is at 15 degrees but I get stuck manually. If it is too cold after the LPG is like you said, if the engine gives too much gas, it slows down (I guess it doesn't burn) I stop accelerating on my own, but now I know your temper, I know where he wants to lpg. border = "0" alt = "Grin" title = "Grin" />
zavur 2011-10-15 00:17:33
08.05.2020 16:14 # 10
I always read and hear this problem. Let's see what the wishes are.
