Stop at 80-90 km speed
08.05.2020 16:46 # 1
erdinho
My car suddenly stopped while peugeot 207 HDI 2007 model at 80-90 km speed. 10 minutes before this incident stopped traffic in the vehicle 1-2 minutes did not work. I think it is due to diesel oil due to water mixing events. Though I bought it from diesel in opet.
08.05.2020 16:46 # 2
toga406
Indication on the screen if there is water.
08.05.2020 16:46 # 3
berk2309
Whatever we have to say, there are many reasons, the diesel filter is blocked, there is something in the pump. There is a problem in engine ignition.
08.05.2020 16:46 # 4
turbo27
the crank sensor does the same thing in its malfunction, its wake becomes like the fuel of the vehicle is over .. and it becomes more frequent in time.
08.05.2020 16:46 # 5
kuzu
Most likely it is caused by the engine inner fuse box. Have your car checked with the original device. If there is a lack of communication with the motor brain in the abs brain, replace the fuse box regards.
08.05.2020 16:46 # 6
erdinho
I had the tool connected to the computer. They did not show a malfunction, they told me he did it because of the diesel. They always said that I had to buy the same gasoline or even the same pump. Now I am extinguished in my fault light. I hope it won't cause any problems again.
08.05.2020 16:46 # 7
istanbullu_3886
reil was doing it because of his sender.
08.05.2020 16:46 # 8
erdinho
last night he left on the road again for the same reason. First I showed it to a master there, take it to the authorized service, they said they would understand better. They said that the fuse box and diesel pump indicator should change. stopping because of this. They spent around 800-850.
