Stop and misfire
08.05.2020 15:02 # 1
favourite
While my friends are running at idle in my 99 model 306 vehicle, the speed rises first, then the speed returns to normal. I went to the industry, the car remained for 1 hour, there was no setback. I even got the engine throat butterfly blah or something. But he does the same thing again. Bari let's not go through industry this week ... Vehicle Gasoline
08.05.2020 15:02 # 2
Allah Allah: ((
If you didn't fix it even though you went to the master, you can also fix your master :))
08.05.2020 15:02 # 3
favourite
The master works normally :)
08.05.2020 15:02 # 4
boranaydogmus
I think change the car then :) joke try another master this week.
08.05.2020 15:02 # 5
Burak07
I have the same problem. When I first started the car, the speed of the car is rising and it is falling, as if it was going to stop.
08.05.2020 15:02 # 6
metin
Try another master, be sure that you will not be harmed.
08.05.2020 15:02 # 7
tugrulavci
[QUOTE = favorite] Friends 99 model 306 in my car when the car is running at idle speed rises first, then the speed returns to normal, sometimes I get a misfire cough or stop while driving in 1st gear. I went to the industry, the car remained for 1 hour, there was no setback. I even got the engine throat butterfly blah or something. But he does the same thing again. Bari, let's not go through industry this week ... Vehicle Gasoline [/ QUOTE]
check your idler
08.05.2020 15:02 # 8
rapsody
I think there might be a blockage in the injector. I had the same type in me. I thought it was dirty, but I said I would change it. I was looking for a little bit of engine, it was spontaneously improved :)) I was getting the gas from the shell. My brother's friend had said it after it had improved.
but he was doing it in all gears, not until it warmed up.
08.05.2020 15:02 # 9
masumserseri
I think the throat butterfly potentiometer is a large potential potentiometer
08.05.2020 15:02 # 10
eneslan
Which city are you in?
