Stop and abs light on 307 1.4 hdi mornings
08.05.2020 16:17 # 1
inceyasar
307 1.4 When I run it in the morning, the stop light flashes 3 times while the abs light is on and the third light goes off after the 3rd burn & nbsp; vehicle & nbsp; does not give any audible or written warning, this event happens only at the first start or when you do not start the car for a long time. Do you think that there is a bit of space on the axles of the brake oil level? Has anyone changed the axle tulip recently?
08.05.2020 16:17 # 2
emin15
possible problem is caused by the battery
08.05.2020 16:17 # 3
If you have difficulties while working, you would realize that there was a lack of battery.
08.05.2020 16:17 # 4
gozem
I have the same ending in me, so my guess is from the battery. I will not fall on it, as I will change it soon.
08.05.2020 16:17 # 5
metin
Hey, I got it yesterday.
& nbsp;
has been burning for the third time when the vehicle has not been running for about 1 year or when the headlights etc. are on for a while, and the abs has been on for a while. I changed it to the crankshaft pulley, but it didn't. The problem is caused by the weak current at first start, so the problem is "BATTERY". I changed it yesterday, it was very good. I don't get the error anymore.
& nbsp;
Get a price from the falcon peugeot for the axle. you get it master.
08.05.2020 16:17 # 6
inceyasar
Thank you for your help, friends, the battery had stepped in the snow last year, but since you say that it will be left on the road in the cold this year, let's handle it as far as it goes, so we will buy a new battery :)
08.05.2020 16:17 # 7
metin
[QUOTE = Inceyasar] thank you for your help, friends, the battery had stepped in the snow last year, but since you say it will be left in the cold on the road this year, it will not be okay to go as far as it will go:) [/ QUOTE]
& nbsp; < / DIV>
I don't think it should go as far as it goes because the battery is an important component and other electronic components could be damaged. I don't know if you would believe it, but when I was listening to a CD in my car, there was a scratch, what is the current of the battery?
08.05.2020 16:17 # 8
inceyasar
For now, even when it is 0-2 degrees in the morning, the battery is pressed, I don't think it will be negative, I think we are trying to renew as much as the possibilities allow but my hand is nothing :)
08.05.2020 16:17 # 9
I am renewed as a student, you will get all kinds :) 120 lira 60amp happy bass installment take I think
08.05.2020 16:17 # 10
metin
[QUOTE = inceyasar] For now, even when it is 0-2 degrees in the morning, the battery is pressed, we don't try to renew it, I think we are trying to renew it as much as possible, but my hand is no text:) [/ QUOTE]
& nbsp;
, what shall we say
