stop?
08.05.2020 14:51 # 1
rapsody
Hello,
2004 206 1.4 I have a gasoline car. In the first start, the car runs smoothly, but when I get into gear and take off, I stop, after 2-3 attempts and a little strain the engine, I can only take off. What is the solution to the problem? the direction of the vehicle is not looking down)
08.05.2020 14:51 # 2
Onur
If it is uphill, then there may be no fuel at the moment.
08.05.2020 14:51 # 3
bulent 77
printing pad may be finished
08.05.2020 14:51 # 4
peugeotefe
Does this happen in your tank when the gasoline is low or too high. Does this fault continue when the car is cold when it is hot?
08.05.2020 14:51 # 5
rapsody
I don't think it has anything to do with the amount of gasoline in the tank, but it does it in the mornings when the car is cold, and in the mornings, the belt warns 3-5 minutes viyk viyk until it warms up ...
08.05.2020 14:51 # 6
peugeotefe
The belt blasting is caused by the tensioner ball. So does this malfunction go when the engine gets hot?
08.05.2020 14:51 # 7
rapsody
yes, when the engine gets hot ...
08.05.2020 14:51 # 8
rapsody
gncl ...
08.05.2020 14:51 # 9
the same problem was in my old car, it was from the fuel pump. I changed it to 110 lira. last month.
08.05.2020 14:51 # 10
rapsody
um ... thank you. i hope i can handle the problem without overcharging it too ...
08.05.2020 14:51 # 11
deniz_206
Get well soon
