stop
08.05.2020 19:09 # 1
metuna84
In my peugeot 207 2006 1.4 diesel vehicle, there are occasional stoppages, even if it does not stop while turning into a street or stopping at the red light or even while going on the road, there are a few jumps in the vehicle as if the diesel is cut and given again. Shocked What are the reasons for them? I changed the diesel filter because it was dirty, but the problem continued. I changed the place where I bought the diesel. At first, there was no problem. Angry I will change the battery soon, and I will be happy if you answer the spark plugs and the battery, but there is no other option. Thanks in advance. Cry
08.05.2020 19:09 # 2
PARADOSK3327
I had the same problem, I renewed my car spark plug ignition coil and filters with gasoline and tube same problem continues :(
08.05.2020 19:09 # 3
_ali_
When stopping, you have to look at the electrical, air or fuel supply systems, you have looked at the electrical system, the injector is also on the turbo and air supply side, it can be idle system only if it is idle or stops while stopping.
08.05.2020 19:09 # 4
metuna84
Thank you, I will definitely look at these things, and only when the jumps during the cruise are going fast, there is a slowdown as if the gas is not adjusted, there are sudden slowdowns when you take your foot off the gas.
08.05.2020 19:09 # 5
PARADOSK3327
let's share
