stop
08.05.2020 16:04 # 1
First of all I congratulate all my brothers and brothers and sisters
I got out of the slap in the morning today, I came to Isparta together with my family. I wanted to ask for an incident on the road. my car has been hit, why can this event come up to me once again i did not care about the slap but i was scared when i was 2 times i am waiting for your help
08.05.2020 16:04 # 2
very interesting situation.
My masters auspicious holidays are waiting for help. Sırıtma
08.05.2020 16:04 # 3
caner kaya
Don't be afraid, it just doesn't have to be cleaned. The throttle should be cleaned.
:D
08.05.2020 16:04 # 4
Ağlama
08.05.2020 16:04 # 5
Don't worry, I had that problem with me. He shifted to reverse gear and stopped the engine as soon as he got on the load. The setting has been improved. Even though I am still out of adjustment :) now it stops once in a while.
08.05.2020 16:04 # 6
black_rock
brother, I have the same problem, tomorrow I will be cleaning in the service
08.05.2020 16:04 # 7
[QUOTE = black_rock] brother, I have the same problem, I will clean it at the service tomorrow.
08.05.2020 16:04 # 8
black_rock
I went to the service today, got it cleaned (30 TL), removed the handcuffs of the puncher, squeezed something, wiped the cloth, I actually did not have it done in the service, I did not trust it, I did not trust it, I did not risk it, I wouldn't risk it, let me see it in the day, let me see it in the day, let me set it up in the day, let me see it in the gas I have the same problem, if the fick stops like it is shaking like this ...
08.05.2020 16:04 # 9
black_rock
Caner brother did not understand you said to reset with the machine. Could you please give me some information?
08.05.2020 16:04 # 10
[QUOTE = black_rock] Caner brothers did not understand if you said to reset with the machine. Could you please give me some information.
I think it says the case of calibrating its engine with the Peugeot Planet 2000 system. However, this process is not necessary if you do not touch the motor part.
08.05.2020 16:04 # 11
[QUOTE = koliva] [QUOTE = black_rock] Caner brothers did not understand what you said to reset with the machine.
The case called the accelerator pedal exercise, does this reset you say?
08.05.2020 16:04 # 12
taksicicocuk
no need to introduce the throttle by removing the ignition key from the vehicle
08.05.2020 16:04 # 13
tilbe307
Did they completely disassemble the throttle? Or is it obvious that they removed the hose of the air filter and cleaned it from the top?
08.05.2020 16:04 # 14
34sea45
I say as someone who has cleaned the throttle several times, if you have a team, it is not very difficult. to check, I realized that after 4 cleanings, I realized that the engine in there was broken and there was no need to clean it later.
08.05.2020 16:04 # 15
black_rock
he had a diaper on his hand, as if it was not disassembled and cleaned, but by the way the car started to stop more often and there was a logo still lit engine unit lamp I think
