stop
08.05.2020 15:15 # 1
cash1912
Help me, friends. The vehicle was 2 weeks, I stopped the car while it was moving, I stopped the LPG from the LPG. it does not come, it works after a short time. When we try to run the vehicle for about 1 hour, they do not find the same thing again, and they do not find the same thing, and the idle will be lost to itself and there will be a little shaking.
08.05.2020 15:15 # 2
many do this problem in their gas ??? First of all, I think it is necessary to understand whether the problem is in the engine or in the lpg system ...
08.05.2020 15:15 # 3
kaan__
http://forum.peugeotturkey.com/forum_posts.asp?tıd=11957&pn=1&title=307-si-olan-arkadalar-ne-olur-bi-bakn
I had a situation similar to review link 2, I explained on the page maybe it will work
08.05.2020 15:15 # 4
cash1912
I used it on gasoline did not stop, but playing in idle. How could we get my friend?
08.05.2020 15:15 # 5
kaan__
Click on the links
kaan__ 2011-04-10 20:26:57
08.05.2020 15:15 # 6
My brother's car is also stopping while on the move. Especially when we release the gear from high speed and cut off the gas, the tachometer of the car drops and stops very quickly. The vehicle was shaking while idling. As far as I understand, my brother had a smaller syringe than usual when he was installing LPG because he wanted to save fuel. The fuel stops because it is low. The performance of the car fell too.
My 206 is LPG but there is no stopping.
If we use high speed in my brother's car or my car, LPG automatically switches to gasoline as if it was finished. :)
08.05.2020 15:15 # 7
semih
Get well soon
08.05.2020 15:15 # 8
When the vehicle is in motion, does it stop when you take your foot off the gas? If so; (it had happened to me in the palio) Imagine that the tube delivering air to the carburetor is "O" when you look across it. You get half of it with duct tape.
Ying Yang In the form, one side remains closed, you leave the other side open.The problem is resolved. Mine was solved.
badires 2011-04-11 16:04:50
08.05.2020 15:15 # 9
[QUOTE = badires] Does the car stop when you take your foot off the gas while it is moving? If so; (it had happened to me in the palio) Imagine that the tube delivering air to the carburetor is "O" when you look across it. You get half of it with duct tape. The problem is solved. Mine was solved.
My interesting method. So what does it make sense? As long as there is an air flow meter in the vehicle, will it not be possible to send the same amount of air to the engine?
08.05.2020 15:15 # 10
I don't know the logic. I told the master about my trouble. He came with the direct sealing of the duct tape. But I don't know what crap he did. All I know is that my car no longer stopped when I was going down the slope and shifted the gear and took my foot off the gas.
08.05.2020 15:15 # 11
boraa
I said that our vehicles (peugeot) will not have LPG. 90% problem in the future, our elders said. I hope you do not have a serious problem. Wall
08.05.2020 15:15 # 12
cash1912
it does not stop when pulling from the gas pedal, it stops while watching normal.
08.05.2020 15:15 # 13
[QUOTE = boraa] I said that our vehicles (peugeot) will not have LPG. 90% problem in the future, our elders said. I hope you will not have any serious problems. Wall [/ QUOTE]
you make me laugh :))
What are you going to say about pugs that don't have LPG on the market? LPG vehicle was past from the side of the emission, they had a malfunction. Dil Çıkarma
08.05.2020 15:15 # 14
azdek
[QUOTE = cecoli] [QUOTE = boraa] I said that our vehicles (peugeot) will not have LPG. 90% problem in the future, our elders said. Wall [/ QUOTE]
SırıtmaSırıtmaSırıtma I was disconnected from the fault because the vehicle with lpl passed by them cecoli ....
08.05.2020 15:15 # 15
boraa
No need for your friends, you need to respect your LPG and if you have a lpg installed in your vehicles, you need to respect the comments on the LPG and you do not need to write a counter reply right away. It will not fail you but does it in others. the vehicle is your KOPTU..1000tl expense. the man is crying. crap thousand thousand money.these are just examples.this purpose of this forum is not to share our ideas of good or bad.If you want to make a reel, please visit the reel making sections of this forum. late LPG fitted peugeot will break down. I heard this from our services. Dil Çıkarma
08.05.2020 15:15 # 16
How it stops when spreading normally. Is it cutting gas? There is a bottleneck in the fuel system then, cutting off the gas without taking your foot off the gas also brings to mind an electrical failure.
08.05.2020 15:15 # 17
[QUOTE = boraa] No need for your friends, no matter if your vehicles are broken, you need to respect the comments on the LPG if your vehicles are fitted with LPG and you do not need to write a counter reply right away. a friend of mine had lpd in Istanbul, the vehicle is KOPTU ..1000tl cost is out of your way. I am sure that sooner or later, there will be a malfunction in the peugeot fitted with LPG. I heard this from our services. Dil Çıkarma [/ QUOTE]
you are right about yourself. Because of the assemblies made by unknowing masters, all vehicles are not KUPUYORRR))
I am asserting ... proper assembly is done and if you do not disrupt the maintenance properly, nothing will happen.
In the troubles you hear, not suc lpg of ....... the ones who installed it :))
If you pay attention, there is a lot of lpg pug in our forum. There is no one living like you are saying ... but that doesn't mean it won't happen. In general, when proper assembly is made, it is proof that there is no problem. What should I say? If you keep it harmful you keep talking :)) you chat with the people you hear it ... we use it here, you talk without using it. You're doing wrong here. I'll say you're right if you use it ... Göz Kırpma For example, we had a conversation behind us. Later he realized that he had assembled bad in his vehicle :))
08.05.2020 15:15 # 18
boraa
So let's say, `` LPG fits to the peugeot vehicles very much, but if there is a fault, it is not because of the car's own feature, but because of the definitive master. '' Dil ÇıkarmaDil ÇıkarmaSırıtma You look from the side because you use it, master. So, when there is a malfunction, you say that the master was not good and give the service money and say it is easier to leave. Star It is true in your opinion, in my opinion is true. .... Göz Kırpma
08.05.2020 15:15 # 19
Anyway, my beautiful brother, let's not extend the matter with you.
I am not looking biased. Whether everyone uses or not lpg what is it for me ??? I'm trying to awaken the LPG consciousness. I am trying to present my knowledge and experience to my very valuable brothers. According to the place, the masters who assembled from the various provinces of our country are looking for me.)))) let's think about ...
I can look objectively and not see the cause of the problem without being biased to what you say because I have subtly different information.
I don't have to prove to anyone what I know as a result. I'll tell you, he knows himself as soon as he takes the field :) Did we understand: D
I want to say it in the presentation. Is it still failing as much as lpg people on non-lpg vehicles ??? idling problems etc. are happening again. don't forget this ...
Let me give you an example. in some 307s they cannot get the fault light out, even though they do. but in some 307s, once again, the fault does not light up ... no wonder ???
the cecol 2011-04-13 14:30:16
08.05.2020 15:15 # 20
The friend who opened the subject still did not give us the necessary answer.
First of all, we need to understand whether the problem is related to the engine or the lpg system.
Page : / 2
