Stimulate These Bulbs
08.05.2020 17:28 # 1
korkusuz202
Hello friends, I will order a license plate on a roof of 206 vehicles. -4-LED-bulb-park-37a038 / productdetails.aspx? ProductID = otm37a038 & amp; CategoryID = 20,024,643
Reviews
in http://www.hepsiburada.com/lis /transformacion-5-mavi-smd-led-xenon-mavi-7000-k-park-ampulu-81b072/productDetails.aspx?productId=otm81b072&categoryId=20024643
fearless202 2013-03-30 18:16:47
08.05.2020 17:28 # 2
I know the license plate lamps W5W. & Nbsp;
08.05.2020 17:28 # 3
Alicilik
T10 is called bottomless bulb and the moon is referred to as w5w in the literature, but w5w is used for halogen models.
If you are going to use either daylight warmwhite or use white. Others look very abnormal and the gloss you want is not.
If possible, 5 leds 5050SMD & nbsp; Get it from the one. They will give the best performance. Reviews
08.05.2020 17:28 # 4
zgr
It fits both the license plates and the ceiling lamp. however, the dimmer function does not work in the ceiling lamp when the doors are closed. the lamp does not go out completely, a very weak light stays on. I tried it was mine. but & nbsp; friends from the forum advised that you can solve this problem by connecting resistor. & nbsp;
08.05.2020 17:28 # 5
gogly35
I wanted to ask when the subject was opened, I bought a led light bulb with blue light outside for the plates, but it did not give the lighting I wanted. There were 5 leds white lights you shared above, the seller said he could give a fault warning. How would you mind this warning ??
08.05.2020 17:28 # 6
Alicilik
[QUOTE = gogly35] I wanted to ask when the subject was opened, I bought a blue light bulb with a blue light outside for the plates, but did not give the lighting I wanted. There were 5 leds white lights you shared above, the seller can give a fault warning. What would you mind from this warning? There are caceller models. Briaz is expensive but does not fail
08.05.2020 17:28 # 7
gogly35
Understood thanks. Let me investigate the models you say
08.05.2020 17:28 # 8
xMEGANx
I bought both of them, I tried them for the longest life of 5 months :) If you want like a man, there are lamps of this type, the price varies between 30 and 50 TL. Lifetime =) and the quality of its light is the same as very vivid and very intense fluorescent. I recommend from them.
08.05.2020 17:28 # 9
gogly35
I guess you say as in BMW models .. We will find the best light by disassembling now .. Only the fault event was stuck in my mind
