Steering wrap
08.05.2020 18:01 # 1
omer_tarsus
The airbag light was sometimes blinking on my car for the last 1 week and it has not been turned on anymore. We have it connected to the computer and learned that there is a problem with the steering winding. It is said that it is being repaired or sold in a complex but there is no guarantee. What should I do? Also, if the Com 2000 could buy a new arm and have a solid old arm inside, its winding could be attached to my vehicle. My car is 2011 c3 but the arm is the same as peugeot 206 307.
08.05.2020 18:01 # 2
Serkan
Sir, I don't know how normal com2000 arms are, but the com2000 arms, which are the rain and headlight sensor after 2008, are different from the ones before 2008, the handles of my 2004 model 206 and 2008 C3 that I use now are not the same.
08.05.2020 18:01 # 3
Alicilik
Do you have a photo?
Also, did you search with lexia while searching for errors? Which piece of code comes out?
08.05.2020 18:01 # 4
omer_tarsus
[QUOTE = Serkan] Sir, I do not know how the normal com2000 arms are, but the com2000 arms, which are the rain and headlight sensor after 2008, are different from the ones before 2008, the handles of my 2004 model 206 and the 2008 C3 that I use now are not the same [/ QUOTE]
The arms are the same in appearance, my car has no rain and headlight sensor fog lamp. The signal lever has no button. rain sensors have auto section, button in headlight sensor works. I guess if I wear that arm.
08.05.2020 18:01 # 5
omer_tarsus
[QUOTE = Receiving] Is there a photo?
Also, did you search with lexia while searching for errors? Which piece of code comes out? [/ QUOTE]
I went to a place that did airbag work with friends greetings. I think the program was something like pp 2000, for peugeot and citroen. The driver wrote something like an airbag igniter, and the friend there said he was from the bandage. He said, "If you want, I can fix it for 150 TL, but I can not guarantee that he can make the same fault after 1 week." He said it would be better if you bought the arms for 350-400 TL. At the moment, I set the photos and add a break.
ömer_tarsus 2013-10-28 13:39:46
08.05.2020 18:01 # 6
omer_tarsus
The arm is the same, there is no auto at the end of the signal lever and no arrow, no auto at the wiper arm
http://bartebben.com/parts/citroen/c5/relays/switch-combination/com-2000-rw-achter-wisser-v(0-auto-1-2)-l.%3e%3e(auto) -.html
08.05.2020 18:01 # 7
albayman
The name of the teacher diagnostic tool is lexia, and the program it uses is peugeot planet 2000. com 2000 under the steering wheel (command: command). It is the strip that contains the circuits called windings.
I think try to get it repaired by an electronics professional who knows this job because the com 2000 new one can be expensive. The equipment of each vehicle may not be the same and rising is risky.
Also, do not go to the way of putting out the resistance and turn off the light, follow the work done. I think resistance is not even a job of 5-10 TL.
I solved the airbag error, I know from there. They received a fee of 100TL.
08.05.2020 18:01 # 8
omer_tarsus
[QUOTE = colonel] my teacher diagnostic name is lexia, the program it uses is peugeot planet 2000. com 2000 under the steering wheel (command: control). It is the strip that contains the circuits called windings.
I want it to be done too, but I do not want it to cost 150 TL and break before 1 month, so I think. If the person who made it guarantees, I would have it done.
08.05.2020 18:01 # 9
slbn
the same problem exists in my 2002 model 307 otm XT. I do not know what will I do. If you find the solution, please share it here.
