steering wheel strange click from the hub.
08.05.2020 18:39 # 1
okaNStarss
For a couple of days, there is a sound coming from the steering wheel on the cobblestone floor, or in all the places where there is a sound like a plastic intermediate material, the fallen navel hitting somewhere.
08.05.2020 18:39 # 2
BurakCnR
Are you sure that the sound you say comes from the belly?
08.05.2020 18:39 # 3
okaNStarss
[QUOTE = BurakCnR] Are you sure that the sound you said comes from the hub, I heard the sound coming from the parquet none, then I realized that it was from the box under the steering wheel [/ QUOTE]
I checked the box under the steering wheel, squeezed the videos, but the sound did not stop ??
08.05.2020 18:39 # 4
BurakCnR
It is also the contact if the sound is slightly shake while you insert the key in the ignition switch and try the key. Because there is no reason to hear sound from the steering hub.
08.05.2020 18:39 # 5
okaNStarss
Well, on Sunday, there was a sound coming from the back doors and the hoperlors wheezing will probably break out.
08.05.2020 18:39 # 6
okaNStarss
ewt friends today I dismantled and looked at it, as the friend said, the screw fixing the contact made the picture loosened so that the room was making a sound :)
08.05.2020 18:39 # 7
BurakCnR
I'm glad you got the problem :)
08.05.2020 18:39 # 8
arachnid
It happened to me sometime. Now the sounds are cut off, but I just realized that the horn sometimes works and sometimes does not work. mine was a horn-bound voice?
08.05.2020 18:39 # 9
okaNStarss
the horn did not work in me at night, I struck the ground, I hit it on the ground, I put it back on, tried to take water into it, made oxide or static :)
