steering wheel locked while driving 307
08.05.2020 18:56 # 1
aturan
hi guys I got the 2004 model 1.4 HDI XR 307, the steering wheel locked while I was cruising, I braked and stopped. improved when the ignition was switched off and on again? Is the steering wheel hydropower? I don't know if there is oxidation in electronic circuits. Thank you for your help.
08.05.2020 18:56 # 2
ERDINC
God has protected, but if your audience is on the highway, care is a must !!!
08.05.2020 18:56 # 3
serdaralisan
password springs can sometimes release itself, which leads to crashing. If it did once, I think take a look, change it if necessary, because it will make your contact again.
08.05.2020 18:56 # 4
sezar206
very dangerous ya god bless
08.05.2020 18:56 # 5
TRK
You have charity given. Get well soon. It's actually a very dangerous situation. I had heard that the same problem was in a Megan II vehicle and that the result was frustrated. It is useful to have it checked.
08.05.2020 18:56 # 6
aturan
Hi, when I was driving with my car, the steering wheel suddenly didn't turn right or left, I stopped slowly while the car was running and it got better when the ignition was turned on, what should I do?
08.05.2020 18:56 # 7
albayman
we turn the key on the ignition to turn it on when the steering is locked. sometimes when I want to insert and turn the key, it does not turn, it turns when the steering wheel is slightly moved. that is, a situation with the contact socket. have the key contact seat checked. the steering lock is in the contact slot because ...
colonel financing 2014-12-29 20:52:51
