Steering Wheel: Hardening or Locking?
08.05.2020 19:36 # 1
3saniye
Hello friends;
When I started the car about 1 month ago, the steering was not activated immediately. He recovered spontaneously after 5 seconds. 4-5 days after that, I started the car in the same way. Although I have advanced 5 meters, the steering is not activated again. This time I turned the ignition off and on and it got better. I have never had this problem after that. It's too cold here. we see -10 -15 degrees during the day. Maybe this also has an effect. Now this problem is from steering hydraulics etc. is it caused by the steering lock? So the steering motor or pump is not activated or the steering lock has not been released?
My car is a 2008 model peugeot 308 1.6 VTi automatic
3sani to 2016-01-13 14:45:25
08.05.2020 19:36 # 2
GokhaN
As you said, there is a possibility that it is made from cold but it must be from the steering pump.
Try it if it's cold, wait for 5 minutes and try
08.05.2020 19:36 # 3
3saniye
As you said [QUOTE = GökhaN], there is a possibility that it is doing cold, but it should be from the steering pump.
How can I understand? What symptom does it give?
