Steering Wheel Control Malfunction
08.05.2020 15:14 # 1
orcunkalayci
Hi guys. The volume up button on the steering wheel control does not work. Can I fix this problem myself? More precisely, I want to ask this. Is it simple to open up? Or is there a diagram or topic about it in the forum ?? Thanks...
08.05.2020 15:14 # 2
sahin-peugeot
Hello,
What is a vehicle?
08.05.2020 15:14 # 3
orcunkalayci
Vehicle 206 X line 2003 model
08.05.2020 15:14 # 4
Remove the plastic just behind the wheel. When you look at this plastic from the bottom to remove it, you will see that there are 2 20 torx screws. There will be a clip on the back of the controller, pull it out and pull it out. Then clean it up, put it back in and try again. I hope it works.
Koliva 2011-04-06 10:38:48
08.05.2020 15:14 # 5
orcunkalayci
Thank you so much. I will try.
08.05.2020 15:14 # 6
[QUOTE = orcunkalayci] Thank you very much. I'll try. [/ QUOTE]
Sometimes this unit may not sit properly in the center. This means contactlessness. This is a known problem. Make sure it fits well in the center (COM 2000) after cleaning.
Koliva 2011-04-06 10:53:07
08.05.2020 15:14 # 7
just307
While I was cruising, there is a squeaking noise from the steering plastic. I think this is the middle top cover.
