Steering wheel adjustment for 206+?
08.05.2020 17:06 # 1
Alicilik
Hello friends,
The volume of the 206 knows little. As I am a big person, I have trouble getting on and off. For this reason, it is necessary to play with steering wheel adjustment. But they did not put this feature on our vehicles.
It looked like there was a little bit of a difference when I looked at the servicebox from the control arm and my own vehicle. When I removed the plastics for the last steering wheel, I saw the place for the steering height adjustment, we fixed it there with 4 screw screws, it can be adjusted manually in the middle of the level, but it will not be easy.
I started to think too. Can we take it from this arm and say what can we do?
08.05.2020 17:06 # 2
Alicilik
actual
08.05.2020 17:06 # 3
spearo
Ali long sedre reviews and the height-adjusted shaft, you can take a replacement height-adjustable shaft and replace it with only a steering knife for the steering column foot handle behind the fixing lever;) this is only by taking the steering shaft. . Member
08.05.2020 17:06 # 4
Alicilik
[QUOTE = spearo] ali long sedre reviews and height-adjusted shaft to find in the hand, and then you need to take a height-adjustable shaft and replace it with the utility knife for the steering column foot lever behind the speed stabilizer arm; it is only by buying a steering column.
What piece of shaft does it mean?
08.05.2020 17:06 # 5
Alicilik
Brother, I still can't take advantage of sedre. I could not find pc with xp.
I just looked at the servicebox. When I was changing the rim, I removed the top and bottom cover. The setting location was obvious. Mine was right in the middle. It was fixed with two screws if I am not mistaken. I think there is a compression system like bicycles instead of those screws in this manually adjustable system.
We will meet with friends this weekend. What kind of system is there for those who will look at it?
The arm in this picture.
This ours in the picture (I entered from chassis)
< br>
08.05.2020 17:06 # 6
spearo
on the photo above you get the part set shaft completely.
your work is in the combi straight unadjusted steering shaft 474 tl set shaft looks 503 tl service boxta
dear psa 30 tl adjusted shaft, congratulations themselves.
08.05.2020 17:06 # 7
Alicilik
[QUOTE = spearo] you get the part set shaft 1 in the photo above. br> [/ QUOTE]
Well, guys, who do not put the 10tl luggage lamp, I am not surprised anymore.
Do you think that only the adjustment part of that shaft will not change?
08.05.2020 17:06 # 8
spearo
Yes, you will buy the complete spindle.
By the way, if the steering wheel is up when the leather steering wheel is tackled, you may have tightened your teeth before you could fit it on your cutters. check out.
08.05.2020 17:06 # 9
Alicilik
[QUOTE = spearo] yes, you will buy the complete spindle, you will only be sold in that piece.
By the way, if the steering wheel is up when the leather steering wheel is tackled, you may have tightened your teeth before you could fit it on your cutters. Check it out.
look after the brother don't return to cruise "LOL" "LOL" "LOL" "LOL"
08.05.2020 17:06 # 10
simurg
Yak you master that vehicle ..
08.05.2020 17:06 # 11
Alicilik
[QUOTE = simurg] burn you master the vehicle .. [/ QUOTE]
I like it when I wash the puppy. Synergy has also occurred in one and now we are together at least 1 hour 7 days a week.
Otherwise I was burning ships with e36 convertible.
08.05.2020 17:06 # 12
simurg
e36 convertible excellent choice german stayyla
08.05.2020 17:06 # 13
Alicilik
Brother I examined the piece today. There are in the publishers they give that part between 100-200 but believe it is not necessary. We have fixed screws there and they put a clamping system instead. That part of the shaft passes through the hinge, nobody knows when it says shaft. There is no need to believe that the joint changes. I am obsessed again, I will give 10-20 and try to get just that piece. It doesn't make much sense to give 100TL to the whole joint. He said 206 + knuckle exits 150tl. I would get it 100. & Nbsp;
08.05.2020 17:06 # 14
ERSOY-06
I will go on sale the day you leave the pejo,
08.05.2020 17:06 # 15
ERSOY-06
08.05.2020 17:06 # 16
ERSOY-06
date
Reviews
