steering shaking
08.05.2020 15:07 # 1
hi friends my 307 xt 90-100 km and after reaching the speed, there is a serious tremor in the steering wheel I wonder if you can help ...
08.05.2020 15:07 # 2
[QUOTE = ose307] hello guys, after reaching the speed of 307 xt 90-100 km and after, I would be glad if you helped, why is there a serious tremor in the steering wheel ... [/ QUOTE]
It is usually caused by balancing or tire alignment. It may also be caused by other reasons, but these are the points to be looked at first.
08.05.2020 15:07 # 3
metin
I think there are two possibilities.
1- The balance adjustment of the tire is broken, while the long run balance on our broadway biker was stuck there on the back of the disc, whose lighter was thrown on the metal track.
2- The wire inside the tire was broken and made a balloon.
Go to a tire man, he solves 99%.
08.05.2020 15:07 # 4
Agree With Text Brother Will Fix Your Tire Problem. Do not forget to ask how much fee he asked before making the problems .. It is not a problem to be taken lightly. Good luck with.
08.05.2020 15:07 # 5
Faruk
If it trembles when it is slow, the front balances are around 90-100, then the rear wheels are unbalanced.
this is in normal conditions. But if it trembles when it brakes when it is going with 90-100, I know the way from discs and even motor ears because it happened to me;)
08.05.2020 15:07 # 6
thank you very much for your help i will get a balan as soon as possible
08.05.2020 15:07 # 7
selcukcivelek
I asked my father, there is a fine tremor in my car.
08.05.2020 15:07 # 8
Muhammet CAKIR
[QUOTE] doing
08.05.2020 15:07 # 9
furkan
cant want a turning lathe
08.05.2020 15:07 # 10
cesar67
I had the same problem, I had a tie rod balance, 4 tires right now :)
08.05.2020 15:07 # 11
metin
[QUOTE = cesar67] I had the same problem, I had a tie rod balance at the same time in 4 tires:) [/ QUOTE]
How did you balance rod to 4 tires (:
I know two wheels are made of rods, 4 wheels are balanced.
Of course if 4x4 is not known (:
08.05.2020 15:07 # 12
I made the balance adjustment on 4 wheels. No problem. Now the car is slipping like oil on the road.
08.05.2020 15:07 # 13
Faruk
[QUOTE = ose307] I made balance on 4 wheels, no problem now, the car is slipping like oil on the road [/ QUOTE]
It makes a great difference after balancing. I could not leave the steering wheel alone when I was going on the long road with 90-100, either I would go right or left. It was as if I changed the car after balance. Sırıtma
08.05.2020 15:07 # 14
bulent 77
4x4 4-wheel rod adjustment is done.
08.05.2020 15:07 # 15
m.peker
the problem is solved if you make the tremble from the balance and have the tire checked.
08.05.2020 15:07 # 16
MemoTech
The tire that expressed the need for balancing in the most beautiful language means :))
