steering shake while braking
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 5008
08.05.2020 20:33 # 1
ahmetk
Hello there,
We became Pejo cu by buying 5008 mrt in the month. But since I bought it, I have a problem with the brakes. Steering trembles while braking. The front disc and pad changed, it seemed like it was cut off. But on vacation I noticed that when braking above 100 km / h it still vibrates again. The speed drops to less than 100.
Is there anyone who has experienced anything like this before?
08.05.2020 20:33 # 2
uzunca961
Maybe I don't know if I can say the balance at speeds.
08.05.2020 20:33 # 3
First of all, how many models are the welcome vehicle?
08.05.2020 20:33 # 4
ahmetk
We're [I'm] glad to be here.
The 2016 model of the vehicle was bought in March this year as 0 km.
When the vibrations increased, I took it to the service when it was 2500 km. The front disc and pad were replaced, but this time the speed started to vibrate when the speed was over 100. We went, rot balancing done.
On vacation, I realized on the long road that the steering wheel still vibrates if you brake when the speed is over 100. Currently the vehicle is at 8500 km or something.
08.05.2020 20:33 # 5
As far as I can remember, the same problems were faced in 5008s without makeup, teacher. It originates from the swings. Which service did you go to? Even the related services had a warning about this issue from French.
08.05.2020 20:33 # 6
ahmetk
I went to Göral.
I will go again tomorrow
08.05.2020 20:33 # 7
warning title of this teacher
08.05.2020 20:33 # 8
ahmetk
Thank you teacher.
I remind this to the service
08.05.2020 20:33 # 9
Mustafa 070777
[QUOTE = ahmetk] Hello,
[/ QUOTE] if my teacher has a slope on wheels, he still trembles from imbalance. The same problem happened with me.
08.05.2020 20:33 # 10
ahmetk
thanks
08.05.2020 20:33 # 11
[QUOTE = ahmetk] Göral went.
Conqueror PEUGEOT is more concerned with mechanical and electronic matters, as in the past in Ankara. be informed my teacher
08.05.2020 20:33 # 12
ahmetk
We are obliged to go because it is guaranteed. I would be glad if you give the address of Fatih Peugeot.
Meanwhile we went on Saturday. We had a test drive with the master. He said there is a tremor at 110 km / h. I did some research on this subject, I said it was the case, and even there was a service bulletin. they said let's see. they said you're right, we will apply it. zodiac signs changed, balance etc was done. We went to the test, they said there was a slight flicker of 120-125 km / h. They said bring it on weekdays and let's check again.
I tried it on the highway on Sunday, as there is a slight tremor on the steering wheel at 140 km / ha, and there is a slight tremor when braking. I don't know what to do, should I take it, or should I turn the discs and rot the outside.
08.05.2020 20:33 # 13
https://www.google.com.tr/maps/place/peugeot-fatih/@39.9487277,32.8413181,17z/data=!4m5!3m4!1s0x0:0x8e837938ab2c8393!8m2!3d39.94969!4d32.840095
teacher behind the riot police. Büyük Sanayi Sitesi 1 Cad NO: 28 İskitler .
I also recommend you to meet with Fatih Peugeot. They have a lot of experience in this type of subject. If it is trembling at 140 km / h speed, I think the axle and front wheel hub control should be done, they even need to change them for free. By the way, even if you do not say, there is no news even about the newsletter on this subject. Confused
sonerkyl 2017-09-11 16:49:14
08.05.2020 20:33 # 14
ahmetk
I left today, it remained from morning to evening. They couldn't stop trembling. shock absorber table limiter has been ordered, they will replace it. There was also a newsletter about this.
08.05.2020 20:33 # 15
[QUOTE = ahmetk] I quit today, it remained from morning till evening. They couldn't stop trembling. shock absorber table limiter has been ordered, they will replace it. There was also a newsletter about this. [/ QUOTE]
Mr. Ahmet, it is difficult to understand these services. There was another newsletter. the service is not looking why we hope this news will be improved. you will get rid of this problem.
08.05.2020 20:33 # 16
ahmetk
Thank you very much.
08.05.2020 20:33 # 17
NNNB
Hi, there was a tremor problem in my vehicle too. Or because the rim is crooked or if there is a flange between the rim and the drum.
08.05.2020 20:33 # 18
ahmetk
Thanks for information. first the disc changed to the pad, then the bushings, then the damper pads. The parts change and the problem fell on the disc again. the disk has been warped again in this time. shaved, straightened.
08.05.2020 20:33 # 19
peugeotefe
Sometimes it can be balanced even in zero discs. It is best to turn the discs in a precision turned lathe.
08.05.2020 20:33 # 20
OguzhanKucuk61
Get well soon, pleasant driving
Page : / 2
