steering pump leaking oil
08.05.2020 19:28 # 1
burak_erat
Hello friends, my car has been missing oil from the steering pump for about 10 days. When I look at it every morning, I see oil traces.
08.05.2020 19:28 # 2
koray.turan
Cikarit yes my pump is broken
08.05.2020 19:28 # 3
KuzuX
Unfortunately, the sister cartering that changes when he is lean is good.
08.05.2020 19:28 # 4
burak_erat
Well, I showed it to the master as I was less complete.
08.05.2020 19:28 # 5
koray.turan
I am shouting very badly. Yag full but sound amazing bad
08.05.2020 19:28 # 6
necdet67
it had happened to me that the flowing oil was flowing to the bottom of the battery charging the copper wires and melting with time. Then one day we stop, the battery sign appears on the screen, you are looking at the control that the battery is strong but it cannot change the part because it has to change the room room workmanship 400 - Get information about 450 ...
08.05.2020 19:28 # 7
burak_erat
As you said, battery problem started to occur in me, it is not fully charged ...
Apparently, up to 500 Turkish lira is stuck: D
08.05.2020 19:28 # 8
madblueblacksea
It is useful to check the condition of the oil. If the oil is too thin, it can leak very easily from the wear that has worn over time. I completely changed the oil and solved the problem, but the room was a coincidence. When I disassembled to make the leak in the hydraulic pipe, I changed the oil and it recovered in the leak in the box. It has not been a problem for 5 months. I think you can change the 20 lira oil and try your luck instead of going into the 300 -500 box. You have to drain the oil from the steering box completely
