Steering pump
15.01.2022 20:42 # 1
aek67
Hello
When I start my vehicle and stop it, after a while, the oil in the form of foam flows out of the hole on the steering pump cover, when I open the cover, it starts to foam and flows. What is the reason?
17.01.2022 10:05 # 2
Hello teacher. There may be too much oil or there may be a problem in the system. I would recommend an oil change. You can do it yourself, but you will have to do it a few times. Get two cans of steering oil. then a large syringe and IV tubing. 15-20 cm is enough. First, draw as much oil as you can and add new oil, then start the vehicle and turn the steering wheel right and left a couple of times, then draw oil again. Top up with new oil. observe again
18.01.2022 16:08 # 3
AEKARABULUT
ok i will try and see what will be the result
