Steering problem
08.05.2020 15:11 # 1
cermiki
Good day to you guys. Friends warned while parking the vehicle at work today. When I broke the steering wheel right and left, they said there was a sound coming. I heard a hissing sound when I started the car and broke the steering wheel to the right and left. the sound is constantly coming when the steering wheel is fully broken. When the steering starts to normalize, the sound stops. My friends, I would like you to enlighten me about where this sound originated from. Ii days to everyone.
08.05.2020 15:11 # 2
motionemotion
that sound is in every normal vehicle
08.05.2020 15:11 # 3
cermiki
The point that keeps my head on is that there is no problem with hydraulics.
08.05.2020 15:11 # 4
when you make a full right full left, the steering wheel is leaned to the end and the pump will make that sound when it is forced. it is perfectly normal. If you do not lean the steering correctly to the right or to the left, then it will be fine. If you force the pump, you will cause it to break down earlier ... only in full electric steering will not it sound. Because there is no hydraulic pump. there is no sound ...
08.05.2020 15:11 # 5
Muhammet CAKIR
When you make [QUOTE = cecoli] full right full left, the steering wheel makes a sound when the pump is forced because the steering wheel rests on the end. it is perfectly normal. If you do not lean the steering correctly to the right or to the left, then it will be fine. If you force the pump, you will cause it to break down earlier ... only in full electric steering will not it sound. Because there is no hydraulic pump. there is no sound ... [/ QUOTE] Thumbs Up you said very right brother hydraulic pumps work with very high pressure. When you press this pressure even more, the pump will obtain an incredible power :) this will damage the hydraulic pump in forcing the pump to be forced. just look at the pug not :) all of them have the same system, leave the steering when it reaches the end, push very little back, do not force yourself more than where it left off
