Steering Problem?
08.05.2020 15:06 # 1
ereneren
friends are doing when the engine is cold 307s have a belt sound, the cold engine makes a high-pitched treble sound, this sound increases when turning the steering wheel, especially when I turn the steering wheel until the end, but it cuts when the engine is warming, it rarely and very rarely makes it once in a while while the engine is warming up when the engine is burning in the park I wonder why it can happen when doing?
Meanwhile, the vehicle was 2005 automatic 307 87000
Thank you to the friends who have already answered ...
08.05.2020 15:06 # 2
[QUOTE] doing it when the engine is warming up, it can cause parking or something.
When parking, the buoyancy generated in the tires is at a maximum compared to that in motion. In other words, the steering pump works at maximum because more force is required. Usually, this sound comes from belts or pulleys. I guess there is a problem with the belt that operates the alternator called the aux belt, the steering pump and the air conditioning engine. This problem may be caused by the axis of the belt slipping or old. This sound can also come from the alternator's pulley. There is a possibility that there is a spool to which this belt is attached to stretch while wearing the same belt. This reel is very hard to break, but it can make this sound when it breaks down.
08.05.2020 15:06 # 3
peugeotefe
Since the PEUGEOT 307s have an electric steering pump system, it is not possible for the belt sound to be related to the steering.
08.05.2020 15:06 # 4
arslan selim
Hi friend. The crankshaft has started to spin in itself. It has a cost of 15 TL. It has 15 minutes of work. .
08.05.2020 15:06 # 5
metin
[QUOTE = arslan selim] hi dude.crank pulley has started to turn inside itself.70 tl is like it costs 15 minutes, it has a crafting time. and high on the long road. [/ QUOTE]
I guess you're talking about missing a hoop. if so I just changed it two weeks ago. I changed to 140 TL pulley + 20 TL labor.
I couldn't understand the 70 TL you said. I ate a pile of us.
08.05.2020 15:06 # 6
peugeotefe
[QUOTE = text] [QUOTE = arslan selim] hi friend.crank pulley has started to turn inside itself.It has a cost of 15 rubles. as it rotates inside itself, and it is likely that it will break on the long road. [/ QUOTE]
You did not eat piles, you had it done at a normal price.
08.05.2020 15:06 # 7
ereneren
Thank you to the friends who answered. Let's take a look at the industry. What will they say there ...
08.05.2020 15:07 # 8
metin
If you are in Istanbul, I believe that he will solve your problem. these cars do not neglect larger problems.
08.05.2020 15:07 # 9
ereneren
there is a familiar place thanks ..
08.05.2020 15:07 # 10
boranaydogmus
[QUOTE = koliva] [QUOTE = ereneren] friends make it when the engine is cold There is a belt sound in the 307s, the cold engine sounds a high pitched treble sound, this sound increases when the steering wheel turns, especially when I turn the steering wheel until the end, but it cuts when the engine gets hot very rarely and very much Doing it occasionally with a faint voice, why could it be parking when the engine is approaching when it is warm?
My 206 car also had the sound of a belt, an increasing noise in the cold. The timing of the vehicle had come, and the masters said it was due to it. This problem disappeared when the timing set and alternator belt changed. I think you should check your timing and alternator sets and change if necessary.
