Steering Oil Leak and Stop
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
11.07.2022 20:35 # 1
altuners
Hi guys,
The multimedia (sound, navigation, display, etc.) system of my 2013 model 508 Active sometimes works, sometimes does not. When I turn on the ignition and start the car, it tries to return the CD even though there is no CD in it. temporarily trying to eject the CD and the screen does not turn on. The radio does not work. It does it this way all the time while on the go. If anyone has encountered this situation before, I would appreciate it if anyone could give information about its repair or replacement. Thank you in advance to those who are interested.
12.08.2022 01:13 # 2
altuners
Dear friends, is there no one among us who has experience or ideas on this subject?
16.01.2023 16:14 # 3
traxformania
I've had similar problems, the best thing is to install an Android unit. I have been using it for about 7-8 years and I am very satisfied.
25.03.2023 17:29 # 4
altuners
I don't want to put something different on it so that it doesn't spoil its originality. There must be a place to fix this situation. If anyone has come across or has a solution suggestion, I would appreciate it if you let me know.
08.09.2024 08:53 # 5
evren1975
Hello. I have the same problem. Altuners, did you solve your problem?
22.12.2024 13:57 # 6
altuners
I researched extensively, going to authorized service centers, private electricians, electronics technicians, multimedia service centers, and all. None of them could solve the problem. Finally, I found Tekin Usta at TEK Elektronik in Şaşmaz. He was aware of the problem, removed the radio, took it back, and told me to come back a day later. He installed it, and the problem was solved. No one else offered to fix the problem. altuners2024-12-22 14:25:43
22.12.2024 19:04 # 7
by_bozkurt
[QUOTE=altuners]I did a lot of research, went to authorized service, private service, electrician, electronics, multimedia service, etc., but none of them could solve the problem. Finally, I found someone called Tekin Elektronik in Şaşmaz. He was aware of the problem, took the radio apart, said to come back a day later, and installed it, and the problem was solved. No one else said they could fix the problem. [/QUOTE] How much did it cost?
23.12.2024 00:10 # 8
altuners
It's been a few months since I had it done and I paid 2000TL.
