STEERING OIL
08.05.2020 19:50 # 1
esstel
I wish everyone good Ramadan ... I watched the oil change in the last net, I want to change in my own car .. (peugeot 307 1.4 hdi) Questions on my mind;
1- Which steering oil should I use?
2- How can I check the steering oil level ...
3-What is the steering oil change interval ...
4-Nothing appears except the oil chamber cover ... tşk
08.05.2020 19:50 # 2
Eyup B.
I do not know the brand, but it is close to the glass in 206 and it is enough to fill the oil with a crush.
08.05.2020 19:50 # 3
akk0212
The control is very simple, open the cover, remove it, there is a bar showing the level below
08.05.2020 19:50 # 4
madblueblacksea
[QUOTE = Eyüp B.] I do not know the brand but it is close to the glass in 206 and it would be enough to fill the oil with a crush.
I have not yet seen a car that has filled the steering oil with hillocks or bought hull oil. Steering oil level is clear, if you put too much, it carries, if you put less, it makes air. This level is usually indicated by the bar on the oil filler cap.
