steering is very hard
08.05.2020 17:21 # 1
dinex
greetings & nbsp; 2004 x line auto 206 I own the steering wheel of my car is very tired. What can I do? Is there a very hard solution ?????
08.05.2020 17:21 # 2
semus
it may be from the steering pump .. you better show it
08.05.2020 17:21 # 3
Demir
There may be a problem with steering pump, records, pads ..
How is the hydraulic level?
Is there a sound?
08.05.2020 17:21 # 4
mev347
I guess it is a general problem for peutos. Everybody talks about steering stiffness.
08.05.2020 17:21 # 5
samet2461
My master has 206 vehicles, my old car marea was very very hard steering compared to him. I'm just having the same problem diode & nbsp; "Big
08.05.2020 17:21 # 6
nurkann
My humble advice, I was complaining because it was too hard on me, the problem may be related to the oil leakage or the rod adjustment of the part called steering sender. After I changed the steering wheel and made the rot adjustment, I started feeling very soft. & Nbsp;
08.05.2020 17:21 # 7
dinex
let's see, I changed the pump, we got zero, we took the nbsp; oil from the shell and put it slowly.
08.05.2020 17:21 # 8
mistik
I had thin sidewall tires 195 45 16 .. I have noticed that when the winter came, I got 14 wheels when winter came and I got 175 55 winter tires. I can now turn the difference on the steering wheel with my finger. /> can also harden the tire size steering wheel ..
08.05.2020 17:21 # 9
dinex
there is no truck like & nbsp;
08.05.2020 17:21 # 10
mami202
my 407 grandparents had the same problem, the steering was greasing and spraying back from where the hydraulic oil was placed & nbsp; when the vehicle was not running, the oil level was low but when it started it was like the oil would foam and overflow, so there was a steering stiffness, I even had a bad experience like this & nbsp;
double lane On the way to 90 la, I had to brake a little & nbsp; hard & nbsp; I had to break the steering first to the right then to the left, but to the left it had a lot of difficulty to break to the left & nbsp; even I thought it would not turn, I stopped on the road, almost & nbsp; after slowing down, I broke to the right and continued my way. But the ones who see from the outside thought they were losing control of the steering wheel & nbsp; they knew they would do their best not to turn the steering wheel :)
serviced repairing the pump, putting oil, labor etc. The price of 130 pounds came out & nbsp;
first we added the oil problem & nbsp; it did not spray or foam, sometimes it seems like the steering wheel is getting harder but it is not like the old one. > mami202 2013-03-03 23:13:09
08.05.2020 17:21 # 11
dinex
TACTICAL IN ANY OTHER PUMP BUT NO DIFFERENCE
08.05.2020 17:21 # 12
rakasan
Wow friend :) I have the same problem with me but it is not so heavy sometimes it gets heavy sometimes it is like normal hydraulic oil:) & nbsp;
08.05.2020 17:21 # 13
barmangino
I have had many chronic illnesses from cüneyt denizli & nbsp; it has been 8 months since 407 and the steering wheel suddenly hardens, and besides these, I guess the oil is missing from the cover of the electric steering pump. Anybody who knows the problem and solution, I don't want to buy a new pump.
08.05.2020 17:21 # 14
mami202
I think you can handle your problem by a master who repairs power steering. Also, don't put it from ordinary ATF oils on the market. style = "line-height: 1.4;"> & nbsp;
< div> Reviews
08.05.2020 17:21 # 15
kursat3006
I also used 206 of the last friend and I realized that my steering wheel was cotton so thankfully it means chronic
08.05.2020 17:21 # 16
atakanka
[QUOTE = mami202] my 407 grandfather had the same problem, steering was greasing and spraying oil from the place where the hydraulic oil was placed & nbsp; when the car was not working it was low oil level, but when it started, it was like the oil would foam and overflow, so I had a steering hardening and even had a bad experience like this & nbsp; < div> I had to brake a little & nbsp; hard & nbsp; while I was going to 90 with a double lane road, I had to break the steering first to the right then to the left, but to the left, I had a lot of difficulty to break to the left & nbsp; even I thought it would not turn, I stood on the road almost & nbsp; after slowing down slowly & nbsp; I broke to the right and continued on my way, but the ones who see from the outside thought they were losing my steering control, & nbsp; they knew that they would do their best not to turn the steering wheel :)
serviced the pump repairing oil etc. The price of 130 pounds came out & nbsp;
first we added the oil problem & nbsp; it did not spray or foam, sometimes it seems like the steering wheel is getting harder but it is not like the old one. > [/ QUOTE]
in which service did you get it and how long did it take? & Nbsp;
08.05.2020 17:21 # 17
Turgay_66
There is no other way to get used to it :)
08.05.2020 17:21 # 18
ahmed206
[QUOTE = mami202]
I think you can handle your problem with a power steering repair master.
Why do I I call this steering wheel hardened.
Does anyone know what the price of this thing is, I want to drain the oil from the pump at the first opportunity and put it in.
