Steering Hydraulic Oil
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
20.07.2020 18:03 # 1
selcukcolak6161
Hello friends. I want to change Partner Tepee's steering hydraulic oil, but I could not drain the oil from the oil filling chamber. I wonder if there is something under the vehicle or what is the tactic.
21.07.2020 10:36 # 2
arifbsrn
My teacher shared something like this on previous issues. I hope it works. [QUOTE = sonerkyl] How to Change Steering Oil? Providing a large injector (syringe) before changing the steering oil will make it easier to change the oil. On average, 1 liter of steering oil is needed for oil change, but especially 3-4 liters on the first try. It is recommended to have steering oil. First of all, there should be a steering oil reservoir under the hood and the oil in the reservoir should be taken out with the help of an injector. The thin one should be removed from the two hoses connected to this reservoir where the oil is added and left in a large container. The inlet of the disconnected hose in the reservoir should also be closed. Then the vehicle is started and oil replenishment is started from the reservoir. In the meantime, the steering wheel of the vehicle must be moved continuously to the right and to the left. The process of adding oil to the reservoir continues until clean oil starts to come from the return hose. After the clean oil starts to come from the hose, the vehicle's ignition is turned off. The disconnected hose is reconnected to the reservoir and finally, oil is added to the reservoir until it reaches the "max" level. [/ QUOTE]
21.07.2020 23:44 # 3
selcukcolak6161
The problem is that when I open the lid of the place where we put the oil, I cannot pull all the oil from there. I guess changing the steering hydraulic oil of Partner Tepee vehicles is not the job of the ordinary user because the pump is in a difficult place.
