Steering hardening, misfire, flywheel sound
08.05.2020 20:30 # 1
semihhns
Hello friends, first of all, good forums.
The first position is as follows; In January, we got the 2007 model 2.0 Hdi 136 Hp 407 (220,000 km). After the vehicle made about 3000 km, the volant started to sound. When I put my foot on the clutch, a slight sang was heard, but recently it started to arrive even though I did not press the clutch. Has anyone changed this track before? If so, how much did it cost? I would like to know what is the situation right now.
The second position is misfire. The vehicle then started to stall until 2000 revolutions (no matter the gear). But they are not kicking a little, these shakes the vehicle. But when he presses a little more and raises the cycle, he stops kicking.
The third position is steering stiffening; When I was driving with my car 2 days ago, the steering wheel got stiff and I got a warning message on the computer screen with the steering wheel and an exclamation mark next to it and saying stop. Then esp gave a warning. This problem got better after turning the ignition off and on, and the steering softened again. But today he did the same thing 2 times again in traffic and then again gave the esp warning.
If you are interested, I would appreciate it. I'm about to go crazy, problems are overlapping
08.05.2020 20:30 # 2
First of all, welcome to us. Let's say your vehicle is good, but the problems seem to be left to you because the old user did not do what he should have done on time. flywheel press pad replacement is around 2000 TL for 2.0. 500-600 tl printing set will be around 800-900 tl flywheel prices. Maybe the flywheel may not be a problem, it is difficult to say something without downloading the shaman. however, the flywheel is released and replacement is recommended. If it kicks at lower speeds, it is useful to have the injectors checked, but first replace the diesel filter. steering problem chronic is usually the most common situation in 407-307-206, but repair is done but how healthy it will be is an unknown good master and guarantee but my advice is change. If it breaks again in the future, then zero money will come out.
08.05.2020 20:30 # 3
semihhns
Thank you very much. If there are other friends who have experienced the same event
and I would be glad if they write.
08.05.2020 20:30 # 4
ismailkaya
hello semih bey If you have a vehicle, of course its problems come after it. First of all, your vehicle is at 220.000 km. What kind of maintenance did the man you received get the information you received? It also seems that the problems of the vehicle are due to the timely maintenance. If I had this vehicle
1- I would have seen the brake pads and so on for the esp malfunction.
2- I would go to the steering and get information about the steering of these vehicles,
3- You said the flywheel failure, but I think it comes from the clutch ball, the dust of the clutch causes the ball to malfunction. the room is making noise, it clears the noise when it presses the clutch. When I pull the foot off the clutch, I think it starts to squeak again, change the clutch set completely but change it at the service.
Replace 4-catalyst with sensors. or make it clean. (very important)
Have 5 injectors maintained. I say
08.05.2020 20:30 # 5
semihhns
[QUOTE = ismailkaya] hello semih bey If you have a vehicle, of course its problems are coming from behind. First of all, your vehicle is at 220.000 km. What kind of maintenance did the man you received get the information you received? It also seems that the problems of the vehicle are due to the timely maintenance. If I had this vehicle
Sir, we sent the vehicle to the industry. I will share the developments with you here.
