Steering hardening
08.05.2020 20:46 # 1
gkhn92
I have researched my problem everybody in a few places, but since I couldn't see someone who has exactly the same experience as I had, I found the cure to open a new topic.
Normally, my steering wheel starts to turn by turning on the steering wheel of the vehicle when it is used for a long period of time or when I enter traffic. After getting stuck for a while, it hardens well and it is not possible to turn the steering wheel when I do not move. About three months ago, I noticed that the steering oil was low on the vehicle and I put the steering oil. I will write the link of the steering oil I put below. This program started after the steering is put in this oil for some reason while it is working normally, this hardening problem is resolved by itself when I go for a while, as if nothing happened. What do you think is the cause of the problem? I also put the steering oil of the master more than the specified size.
Steering oil: http://www.peugeotmarket.com/PEUGEOT-307-HIDROLIK-DIREKSIYON-YAGI-ORJINAL,PR-707.html gkhn92 2018-02-14 20:47:00
08.05.2020 20:46 # 2
RP393
When the oil is heated and expanded, it becomes unable to move inside the pipes and pump. This means hardening. In this way, a good chance breaks out from somewhere. The bad possibility is that it disrupts the pump. Lower the oil to the level it should be. Do not mix different oils in one.
08.05.2020 20:46 # 3
gkhn92
How can I lower the oil level? Is there a method you know? I can't go to many masters because of my work right now, at least I want to try this method
08.05.2020 20:46 # 4
RP393
[QUOTE = gkhn92] How can I lower the oil level? Is there a method you know? I can't go to many masters because of my work right now, at least I would like to try this method [/ QUOTE]
Take the aquarium air hose from petshop up to 1 meter. Pull it like a diesel with that hose. Be careful, do not swallow. It leans when you tip the end of the hose down. Put the excess oil in a bottle. If you pull too much, it will be possible to put it back. Or if it decreases one day tomorrow, you will complete with that oil.
Be careful not to let hydraulic oil come to engine body parts etc. to the bodywork. Erodes.
08.05.2020 20:46 # 5
gkhn92
ok let me try it thanks
08.05.2020 20:46 # 6
talip206
You can buy a serum set at the pharmacy. You can take a large syringe and pull it. talip206 2018-02-15 13:26:36
08.05.2020 20:46 # 7
gkhn92
Oversized syringe worked, I reduced the oil to the required level. However, the problem continues. When I am not in traffic, it is like cotton, but I am a bit of traffic or I wasted and the car is running and it gets hard instantly
08.05.2020 20:46 # 8
gkhn92
I took the vehicle to 2 masters. One of them said that the direct steering pump will change, it did not even look right, so I asked for another place and that the fuses saw oil there. We have to look at this place and if it doesn't get better after cleaning, we will replace the pump. I don't know if you think I should trust or make sense. Because the pump is not a cheap part.
08.05.2020 20:46 # 9
atasoy
I did not use my car for 3 weeks. After starting the car, I was only able to maneuver 8-9 due to bad parking of other cars. My steering pump is now disabled. The steering was like truck driving. They eventually replaced the pump. Even the steer steering pumps are sold for 900 TL. Even the worst master takes 250 TL of labor. Find a master who is behind your trusted job and get it done. The second time you don't want to give these money for the same job ...
08.05.2020 20:46 # 10
ggitaristt
My brother was like that at the beginning, it was going off once in a while and then it became more frequent.
I think your problem is the electronic card of the pump like mine. It will be less than half of the pump money.
08.05.2020 20:46 # 11
gkhn92
Do you know a master I can get in Istanbul? There is no trust in anyone. How much did it cost you? It was a bit of a breakdown in the meantime, and when the costs such as inspection and maintenance were incurred, I began to have financial difficulties.
08.05.2020 20:46 # 12
Selcuk55
Gokhan brother pump will either change or be repaired, I lived in the connection, I had the same thing repaired for 300 liras, but it is better to have a new master put the pump on someone who does not know the job. Wink
08.05.2020 20:46 # 13
gkhn92
I think that if the pump is defective, it will not work, am I wrong? There is no problem when I do not enter traffic etc. in the result. I enter without stopping for 3 hours, there is not the slightest problem, but I get into the traffic for 20 minutes and the pump turns off. Today I met with 1-2 masters, first they should look at the electronic parts, then they said the pump would change
08.05.2020 20:46 # 14
Selcuk55
Already in the pump right here, when it is installed or when it hardens, it gives some relief, the traffic is low and your foot is always in the gas and relaxes, but the pump does not lubricate because you do not give off the gas when you stop.
