Steering hardening
08.05.2020 20:02 # 1
sahinli
friends, easy come my car 2006 look 307 3 months ago the steering pump has failed, I got it out a few weeks, it went well after it fuse blown, after I put the fuse 100, it started to get harder according to its head, now when i run it in the morning, after a few km road and turning on the contact, I am normal sometimes I got right and left again hardened so I joined the forum from kalitertor izmir.
08.05.2020 20:02 # 2
first of all, welcome to come out, parts, luck, my professor does not upset the part for years, some will experience the same problem after 2-3 months, as you have experienced. You can find many topics in the forum if you search. When it comes to the subject of the master, friends from Izmir will help. I'm throwing a link to one of the topics. good forums
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=43122&title=307-direksiyon-sertles
08.05.2020 20:02 # 3
sahinli
thank you for your interest, but the master says that if the pump has a problem it won't
08.05.2020 20:02 # 4
You are welcome, teacher, most likely, oxidation in electronic circuits, etc. There are many topics in the forum, I hope your problem will be solved as soon as possible.
08.05.2020 20:02 # 5
outlaw
[QUOTE = sahinli] friends, easy come my car 2006 look 307 3 months ago the steering pump was broken, I got the fuck out, it went well for a couple of weeks, then the fuse was blown. after closing it normally but sometimes when it is full right left again it hardened and so I joined the forum from the kalitertor izmir CAN I SAY AND SAY ME MASTER THAT WILL NOT KISS ME
First of all, let me tell you about the incident that happened on Sunday, my brother has 106 xr 4 doors. The owner had dismantled the steering pump, we found it, we found it, we used it for 4 years without any problems, but as you said, there were occasional hardening, as you did, the ignition was correct, it was getting better recently. ..
I will go to Migros on Sunday, the steering has hardened, the contact has not turned open, so I went to the parking lot, a smell came around 1 km. We went to the problem in time, the plates inside the pump were breaking, since I bought an outlet, the pump's shorter life has come to me, thank goodness, there is nothing in the electrical installation, there is nothing like zero pump price, if you buy 1,750 TL, there are 600 pumps that will be disturbed. Zero, 300 TL is a lot of people who used it, said there is no problem, we said okay. We are very careful about the cost of the second hand pump.
