Steering hardening
08.05.2020 15:54 # 1
fastfox06
hello everyone..when I was on the move with the steering, the steering hardened suddenly, I used a lot of power to turn it to the right, turning it to the left, while the box turned out to be normal. ..
08.05.2020 15:54 # 2
mehmet1965
If you introduce yourself first, I will have friends who will help you immediately.
08.05.2020 15:54 # 3
fastfox06
Sorry, I'm new here .. my name is ankara ... I don't know how to promote it in this environment .. Thanks to everyone already
08.05.2020 15:54 # 4
I http://forum.peugeotturkey.com/forum_topics.asp?fıd=22&title=yeler%ddm%ddz%dd-taniyal
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 15:54 # 5
fastfox06
I think the problem came foreigner.
08.05.2020 15:54 # 6
iibrahimm
form rules you need to introduce yourself first, then first one helps
08.05.2020 15:54 # 7
mon
If the steering becomes stiff, there is a malfunction in the hydraulic component. either the pump is not working or its oil is low or the belt is stripping or there is a leg in the hydraulic pipes. maybe it has an electronic malfunction. you should check them out. the problem is not foreign, we are foreigners without introducing yourself to you ...
08.05.2020 15:54 # 8
fastfox06
Thank you ... for your help ...
I introduced myself here .. I wondered when I was sending
08.05.2020 15:54 # 9
metin
[QUOTE = fastfox06] thank you ... for your help ...
It would be better for you if you can compress it next to the province in the district.
In the signature part, it will be complete if you share the model fuel type engine volume, etc. of your vehicle.
08.05.2020 15:54 # 10
metin
If the [QUOTE = mon] steering becomes stiff, there is a malfunction in the hydraulic component. either the pump is not working or its oil is low or the belt is stripping or there is a leg in the hydraulic pipes. maybe it has an electronic malfunction. you should check them out. the problem is not foreign, we are foreigners without you introducing yourself ... [/ QUOTE]
I think it is an electrical problem that the pump has been switched off and then started working again since mon got better when the car started.
08.05.2020 15:54 # 11
Faruk
If the steering wheel gets stiff, it may be starting to cut off the axle, making a little bit left and making a ringing noise.
08.05.2020 15:54 # 12
fastfox06
Thank you for your comments .... Meanwhile, it started to wear more often ... I looked at the oil did not diminish ... I should show it this week ... I'm afraid the cost will come out ..
08.05.2020 15:54 # 13
fastfox06
08.05.2020 15:54 # 14
toprakk
absolutely the price of the steering pump is about 120 to 200. I think you should do it as soon as possible, hardening in the road can have bad results: S
08.05.2020 15:54 # 15
fastfox06
Yes, you are very right. I will share what is there after the repair at the service.
08.05.2020 15:54 # 16
sahin-peugeot
[QUOTE = soil] is definitely about 120 to 200 at the price of the steering pump. I think you should do it as soon as possible, hardening in the road can have bad results: S
you are talking about something wrong, probably there is no steering pump between 120-200
08.05.2020 15:54 # 17
Emre Ekrem
yes, my car has a steering wheel stiffening too and when I turn it to the left there is a ringing sound, I didn't want to write extra when it comes to the subject
08.05.2020 15:54 # 18
In 307s, the steering is electro-hydraulic, and the pump is electric. It does not take mechanical action with apricot. When it comes off, the steering is like a truck. The reason for the complaint is the engine of the very clear pump. As far as I know, the pump and the engine are together. I do not know if it will be repaired ...
08.05.2020 15:54 # 19
[QUOTE = undertaker] yes, my car also has steering stiffening and there is a ringing sound when turning to the left, I didn't want to write extra when it comes to it [/ QUOTE]
I'm different than yours, bro. In your vehicle, hydraulic pump works with belt pulley movement. It is necessary to check the system. Could sound be heard from the table balls etc ??
08.05.2020 15:54 # 20
Emre Ekrem
[QUOTE = CeCoLi] [QUOTE = undertaker] yes, my car also has steering stiffness and there is a ringing sound when turning to the left, I didn't want to write extra when it comes to it [/ QUOTE]
When it is turned to the left where it is, it makes a noise and even sounds rather than you know.
Page : / 2
