steering control worked (with video)
08.05.2020 17:14 # 1
istanbullu_3886
Hello friends, for a long time, I was hesitant to attach the steering wheel and the reverse gear sensor so that it would not work on the double tape. I read the steering wheel control in an advertisement that I saw on the internet before I received the tape, I talked to the owner of the phone on the phone, he said that the steering control of the apparatus that he would send would work 100%. So I called my friend who worked in the company of DIIGOM, a pioneer manufacturer, and asked the masters there that the steering control was absolutely impossible. As a result, I ordered the apparatus, I had no opportunity to give up yesterday morning, I bought the apparatus from the cargo early yesterday, and I came to work, I would buy the tape today, I could not beat my curiosity and went right away. I would like to thank sinan GÜNDÜZ who sent the steering control from here. calisti / 6799469 "target =" _ blank "rel =" nofollow "> http://www.izlesene.com/video/307-direksiyon-kumandasi-calisti/6799469
Serco05 2012-12-30 20:31:41
08.05.2020 17:14 # 2
Serkan
Good luck Turan Abi, bye, copy the video link directly here Abi
08.05.2020 17:14 # 3
istanbullu_3886
thank you serkan above I copied the lingi if you can delete the excess, thank you
08.05.2020 17:14 # 4
Serkan
[QUOTE = istanbullu_3886] thank you serkan I copied the lingi above, if you can delete the excess, thank you
I added to the first message Abi link, good luck again.
08.05.2020 17:14 # 5
istanbullu_3886
[QUOTE = Serco05] [QUOTE = istanbullu_3886] thank you serkan above I have copied the lingi if you can delete the excess
I added it to the first message Abi link, good luck again.
[/ QUOTE] thank you bro
08.05.2020 17:14 # 6
Alicilik
[QUOTE = istanbullu_3886] hello friends, I have been hesitating to wear the steering wheel and the reverse gear sensor so as not to disturb the original on the double tape. I read the steering wheel control in an advertisement that I saw on the internet before I received the tape, I talked to the owner of the phone on the phone, he said that the steering control of the apparatus that he would send would work 100%. So I called my friend who worked in the company of DIIGOM, a pioneer manufacturer, and asked the masters there that the steering control was absolutely impossible. As a result, I ordered the apparatus, I had no opportunity to give up yesterday morning, I bought the apparatus from the cargo early yesterday, and I came to work, I would buy the tape today, I could not beat my curiosity and went right away. I would like to thank sinan GÜNDÜZ who sent the steering control from here. calisti / 6799469 "target =" _ blank "rel =" nofollow "> http://www.izlesene.com/video/307-direksiyon-kumandasi-calisti/6799469
Good luck my teacher
It was discussed very much in the forum alone. Digicom not only knows what the import company specifically knows how and how it will work.
I have been using the apparatus for about 2 years. I bought it from abroad, there is no problem. Just a little high cost. Reviews
08.05.2020 17:14 # 7
fatihgg
If you put it in Turan, what would I say :) keychain on ten numbers and songs "Clap" & nbsp; use by gule
08.05.2020 17:14 # 8
Semih CAVDAR
Your health has been number 10 ... Also, this tape is not something but I liked it very much:)) & nbsp;
08.05.2020 17:14 # 9
_semihk_
where did you get the apparatus hojam ??? Is it mounted on your own original arm?
08.05.2020 17:14 # 10
elsoberano
it is very nice.
08.05.2020 17:14 # 11
istanbullu-3885
We have a total of 6 thousand lira music system. Tape is PIONEER AVH-2400.
08.05.2020 17:14 # 12
abdullahcolak
Is there an advertisement link of the apparatus? I had the pioneer AVH-P8550BT model installed.
08.05.2020 17:14 # 13
Alicilik
[QUOTE = abdullahcolak] Is there an advertisement link for the apparatus? I got the pioneer avh-p8550bt model 2004 without a make-up case. Will it work at 307? itm / PI O NEER-PEUGEOT-206-307-Steering-Wheel-Stalk-Adaptor- / 350268992937? pt = UK_Cars_Parts_Vehicles_Terminals_Cabling_ET & amp; hash = item518da8ada9 "target =" _ blank "rel =" nofollow "> http: www. ebay.com/itm/pıoneer-peugeot-206-307-steering-wheel-stalk-adaptor-/350268992937?pt=uk_cars_parts_vehicles_terminals_cabling_et&hash=item518da8ada9 Reviews
08.05.2020 17:14 # 14
abdullahcolak
so is this pioneer double religion compatible with tapes? Does it cause any problems?
[QUOTE = Appealing] [QUOTE = abdullahcolak] Is there a link I got the pioneer avh-p8550bt model 2004 without makeup make-up work at 307 steering control I wonder [/ QUOTE]
http://www.ebay.com/itmPIONER -PEUGEOT-206-307-Steering-Wheel-Stalk-Adaptor- / 350268992937? Pt = UK_Cars_Parts_Vehicles_Terminals_Cabling_ET & amp; hash = item518da8ada9
08.05.2020 17:14 # 15
Alicilik
well, is this pioneer double religion compatible with tapes? Does it cause any problems?
[QUOTE = Receiving] [QUOTE = abdullahcolak] is there an advertisement link of the apparatus? pioneer I had the avh-p8550bt model 2004 without a make-up case would work at 307 steering control [/ QUOTE]
http: //www.ebay. com / itm / PIONEER-PEUGEOT-206-307-Steering-Wheel-Stalk-Adaptor- / 350268992937? pt = UK_Cars_Parts_Vehicles_Terminals_Cabling_ET & amp; hash = item518da8ada9
[/ QUOTE] [/ QUOTE]
Compatible with all pioneer tapes with WR (wired remote) input on the back.
08.05.2020 17:14 # 16
SDYMZ
good health to your hands
08.05.2020 17:14 # 17
tellotello
so is this pioneer double religion compatible with tapes, would it be a problem?
[QUOTE = Buyership] [QUOTE = abdullahcolak] Is there an advertisement link for the apparatus? I got the pioneer avh-p8550bt model 2004 without makeup make-up case will work at 307. .com / itm / PI O NEER-PEUGEOT-206-307-Steering-Wheel-Stalk-Adaptor- / 350268992937? pt = UK_Cars_Parts_Vehicles_Terminals_Cabling_ET & amph hash = item518da8ada9 "target =" _ blank "rel =" nofollow "> http: /www.ebay.com/itm/PIONEER-PEUGEOT-206-307-Steering-Wheel-Stalk-Adaptor-/350268992937?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item518da8ada9
It is compatible with all pioneer tapes with a WR (wired remote) input on the back.
If you have a WR (wired remote) input (i.e. compatible) I am selling, you do not have to worry about waiting & nbsp; "Big.
08.05.2020 17:14 # 18
abdullahcolak
Isn't there a friend doing this job in Istanbul?
08.05.2020 17:14 # 19
scorpion_enis
I have this double din from me and I want the steering control to work. Is there a place I can buy in Izmir? I would be glad if you send a message from pm.
08.05.2020 17:14 # 20
Mesut48
I wouldn't understand if this episode of work in Pioneer Deh1220 would be :) div>
Page : / 2
