Steering, Abs and gearbox
08.05.2020 20:58 # 1
mekici
Hello, about a month ago I bought automatic gear 307 2004 model 307. There is a problem in the steering wheel, it turns like a slight twist then it turns. When I turn it where you stop, when I run it soft, it instantly hardens when turning right and left softens. For this problem, they replaced the steering pump with dislocation, it has improved a bit compared to the past, but it has not passed completely. Also, when I come with the softness that I run first, the softness that I parked is not one and the light is hard when I return. When going fast on the road, when the steering becomes stiff, it stays hard.
Abs does not light when it starts up, but when it goes 100 m, it says abs fault. Within 100m, mule-like sounds come from the brakes. It was always burning before, I changed 4 discs and pads, then it was not lit then it started to burn.
Finally, if I remove the gearbox without heating the car in the morning, it gives automatic gearbox error shortly after. There is no problem when I stop and run, I can continue. The gear shifts are a nice nuisance. Slightly hard only when cold. When I connect it to the computer, I think the gearbox heat signal error also gave a pressure error. Abs also gave the right rear sensor error. If someone has experienced these before, I am waiting for your help. I can not repair the gearbox where I am, and if I can reconnect it to the computer, I also write the codes.
Mekic of 2018-07-23 18:44:32
08.05.2020 20:58 # 2
First of all, welcome to us. We wish you to use your vehicle without accident and good luck.
There are two reasons for the steering problem. My teacher is either in his fuse or due to the oxidation and wetting of the electronic card on the steering pump. The repair is being done. Unfortunately, if you have just replaced the disc and pads, the problem is caused by abs sensors. does not improve without changing. But it is necessary to disassemble and clean it well and try it like that sometimes the problem disappears. When it comes to gearbox, unfortunately, al4 gearboxes can eliminate the chronic problems of my teacher with the change of two solenoid valves and gearbox oil. Or it can only happen with the change of shampoo oil.
08.05.2020 20:58 # 3
mekici
Thank you. I will take into account what you say the next time I take it to maintenance. When I get it, I share the developments again.
08.05.2020 20:58 # 4
mekici
Hello again, I fixed the Abs problem again. I replaced the sensor on the right rear tire, but it did not improve again, then the reader cleaned the part then it improved. For the steering, they cleaned the socket in the pump and I can not say that it was still a bit passed. But I want to say something with the picture. They said that there are no reader bracelets on this wheel, but mine is old model and the reader part is inside. They said that if you use it for the gear, use it in the future, there is no need to go to repair.
