steering?
08.05.2020 16:23 # 1
106_Quiksilver_07
Hi guys, I have a bad noise from my steering wheel for a long time, even when we come to the bumps or go into a light pit on the way, it will get stuck and disturbed.
08.05.2020 16:23 # 2
aslanparcasi
steering wheel. Does the steering take place in full right or left turns?
08.05.2020 16:23 # 3
feline
Dude, hold the ignition key with your hand on the way, let's see if the sound is cut off, there is a small screw there, it loosens and drives the man crazy.
08.05.2020 16:23 # 4
yavuz25
Check the rock heads, tie rods and steering gear.
08.05.2020 16:23 # 5
okankrgz
z rods, tie rods, you can have a look at the steering knuckle..the worst case is the steering box
08.05.2020 16:23 # 6
aacayp
I had the same problem with me, the axle was cut and the vehicle was made from 120 rubles with less labor.
08.05.2020 16:23 # 7
by_imp
I have a problem like this, when it turns left and right, sometimes a loud voice called kut sounds
08.05.2020 16:23 # 8
Ucyuzalti
Look at the Z-joint
08.05.2020 16:23 # 9
Ucyuzalti
I know a situation related to flow
08.05.2020 16:23 # 10
106_Quiksilver_07
Thank you very much for your attention.
08.05.2020 16:23 # 11
aopena
1 steering knuckle
2 steering boxes if there is a lot of rattling and on the bad road, there is a belt in the hinges, then it will hang out and the sounds will be caused by blows in the mouth, it is most likely that the tires inside it are worn out, it may sound like that, but it can make it in the steering box & nbsp; < / div>
08.05.2020 16:23 # 12
Muhammet CAKIR
Look at the front team, you are not related to the steering wheel.
