Steel rim size
08.05.2020 17:07 # 1
s.uzan
My car is 2005 model 206 X line. The original one had 14 "wheels, but the guy I bought had a 15" steel wheel and a thin cheek performance tire. now when I measure the diameter of 14 "(tire + rim) tires on my neighbor's car, it is about 2 cm longer than the 15" (tire ++ rim) tires on my vehicle. how this affects the vehicle's speedometer. Does it show wrong. in my opinion it shows less. what can I do
08.05.2020 17:07 # 2
Alicilik
they fix it in the service. They go to the authorized or private service and handle it with pp2000.
Since the cheek sizes are of certain sizes, it is difficult to make the difference in 14-15 passes. I do not know the difference in speed, but you are more profitable in km. If you go 100km, 98km fln varies on the counter.
08.05.2020 17:07 # 3
If you can give the tire sizes, it can be calculated exactly.
08.05.2020 17:07 # 4
s.uzan
I just calculated. Original tire sizes for peugeot 206 175/65 / r14. When the circumference of this tire is calculated, the radius is r = 29,175 cm. The tires installed in my vehicle are 195/50 / r15. its radius is r = 25,65cm.
the circumference of r14 is 183,312 cm, the circumference of r15 is 161,164 cm. the difference between the two is 22,148 cm. So I go 22,148 cm incomplete roads on every wheel turn of my vehicle. naturally I have a slower speed than seen on my speedometer. & nbsp; For example, if I go with 90, my actual speed is like 87. what is the way to fix this. new 4 pieces of 14 "steel wheels & nbsp; how much is the money. The rear tires of the vehicle will change already. I wonder if I give them to the tire, and if I give the wheels in my car, it gives me 4 new 175/65 / r14 tires and steel wheels that are used. I am waiting for your solution suggestions. > 2012-10-31 10:37:59
08.05.2020 17:07 # 5
s.uzan
[QUOTE = Receivable] correct this in the service. They go to the authorized or private service and handle it with pp2000.
Can they hold the km exactly. or will it work if I change the tires if the 15 "rim is stuck in the vehicle?
