steady motor fault light
08.05.2020 20:41 # 1
yusufmercan
When I went to the electrician for this malfunction light, which was constantly burning in my 2000 model automatic 1.6 306 vehicle, he said that he had gas in the car, he made it from the oxygen sensor. is it possible
08.05.2020 20:41 # 2
Hodja, first, take a gas, use it like 100-150 km. then go to the lpg setting but you need to find a good master will make the settings straight
08.05.2020 20:41 # 3
RP393
I have the same problem on my 206 cars. When it goes 70-80 km on gasoline it goes out. It burns when 70-80 km goes in LPG.
It is on from the LPG setting. I did not handle the winter LPG setting. The master will change the injection times and will improve when the air is heated.
The oxygen sensor is not faulty, it burns due to the fuel adjustment of your vehicle. The sensor is not something that easily breaks down, do not waste money.
08.05.2020 20:41 # 4
yusufmercan
In my car, it is burning in gas, it is in the gas, for example, I deleted all of the faults from the computer, I do not know what the malfunction is going on.
08.05.2020 20:41 # 5
[QUOTE = yusufmercan] I do not know what is going on in my car, gas is burning in the gas, for example, all the malfunctions from the computer has been burned.
First you need to learn the error code, brother. According to him, let's try to help with our knowledge.
08.05.2020 20:41 # 6
yusufmercan
Is there a good electrician in Ankara?
08.05.2020 20:41 # 7
[QUOTE = yusufmercan] If you have a good electrician in Ankara, I recommend a place that connects with a computer or something [/ QUOTE]
unfairly alsancak come to the auto, they have the original software in their hands.
08.05.2020 20:41 # 8
yusufmercan
Okay brother thank you very much
