STAYING ON THE WAY :(
08.05.2020 18:19 # 1
simsek 307
Guys, I have a problem. I had a LPG a while ago. users know, gasoline does not show constantly. When this is the case, there is no way or absence :( I do not miss the gasoline but sometimes it is human. I have a can :)) but I wonder, in this case, will the car also work on LPG? I do not know if there is a method for this. Or should I visit the gas can filling?
08.05.2020 18:19 # 2
herry
Even if you go at the LPG as km progresses, the gas gauge is falling, someone in the industry is more solemn, search the internet, and there are bicycles that make the needle drop when using only gasoline. Do you fix it when you wear it. I think it is healthier than carrying a can.
08.05.2020 18:19 # 3
Serkan
On most systems, if you start by holding down the LPG, gas-switched button, the vehicle will run directly on the LPG, but it has a limit, for example, allowing it to work 20 times in lovato. After 20, it is necessary to connect the computer and reset the counter.
08.05.2020 18:19 # 4
simsek 307
yes i heard that I tried but it didn't. maybe I couldn't do it right. I'll try again.
Well, in all lpg cars, the indicator does not fit this way, or does my 307 model not fit? Of course I ask for those who hang out later.
08.05.2020 18:19 # 5
Serkan
In general, if you move the tank over half tomorrow, the display shows the correct measurement again after the bottom falls, I keep it over half the time until the next fuel is taken, I always hold it over half, it measures again and shows the correct fuel at the first start after giving the fuel warning.
08.05.2020 18:19 # 6
simsek 307
it means that it cannot detect without a half tank. What will I do? I think there is no need to have other things installed on the vehicle and spoil it. there may be things he can't handle Smile
08.05.2020 18:19 # 7
oguzhan29
there is a little kit, it doesn't fall with the gas gauge when you plug it in
08.05.2020 18:19 # 8
Serkan
[QUOTE = oguzhan29] There was a little kit, the gas gauge does not drop with the lpg when you attach it.
The Psa module measures the fuel in the tank every time you start the car, something a little costly, you can easily use the alternative, which is close to the forum for free, but I think there is no need to follow the best, and not to drop it under the quarter tank at 20 pounds in every 2-3 lpg purchase. If gasoline is taken no problems will occur.
08.05.2020 18:19 # 9
simsek 307
Yes, I think the same way, Mr. Serkan. best to follow
